dont really know - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-14-2011, 03:28 AM Thread Starter
instagator apperently
Nuttin up's Avatar
Question dont really know
is the 17* hpop out of 99-03 sd and will they work for the obs 7.3s and if so what would u have to do to change then out
Nuttin up is offline
post #2 of 7 (permalink) Old 04-14-2011, 03:29 AM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: dont really know
yes it will work, throw it in and be done
Fordfreak4life is offline
post #3 of 7 (permalink) Old 04-14-2011, 04:00 AM
95powersmoker's Avatar
It will only work in a 96-97 truck... For a 94-95, it will not.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 7 (permalink) Old 04-14-2011, 02:42 PM
Haters Gonna Hate
Please explain...... I have always been under the impression it would work in all of them. Then again I'm just a lowly 6blow guy
post #5 of 7 (permalink) Old 04-14-2011, 03:53 PM
94-95 trucks have the antidrain back check valve. 96+ trucks do not, so throwing a SD pump on the earlier OBS trucks will cause drain back issues and therefore you will be filling the res to get the trucks started every morning. One way of fixing this would be to mod the front cover but that's a lot of work when you could just send your factory HPOP out to a builder like Terminator and have them mod it to a 17* (which is what you are trying to accomplish with the SD pump) leaving the check valve...
For the Later year OBS trucks, You can throw in a SD pump and not worry about the drain back issues because they didn't come with the anti drain back check valve.
So, to clarify, 94-95 obs trucks, NO a SD pump will not directly swap. 96+ trucks, YES SD pump is drop in.
James
post #6 of 7 (permalink) Old 04-14-2011, 04:33 PM
The Original
BigStroker's Avatar
Basically what he said or you can send it to Stealth.
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #7 of 7 (permalink) Old 04-14-2011, 06:13 PM
OBS Addict
7.3psd97444's Avatar
thanks for that info, i always wanted to know this.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
