Changed oil ...now wont start. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-12-2011, 10:22 PM Thread Starter
I have a 97 F250 powerstrike 7.3L
It sat for a while when I didnt have the money to repair the E4od trans.
Replaced the trans and took it for a test drive. ( about 30 miles)
Ran great. The next day I moved it to the other side of my lot to change oil and filters. Going up the hill it seemed that it didnt have as much power as the day before. I thought maybe just hadnt warmed up yet. I changed the oil and oil filter. Went to move it and it would not start. I have checked the reservoir for the HPOP and it is full. If I disconnect the right side HP oil line I do get flow but not very much. I have fuel pressure of about 28 PSI but no white smoke. The glow plugs are getting power through the relay and the WST light is functioning. Tach also seems to be working on cranking.
I have disconnected to right side HP oil line and capped off but no change in status.
I think my next step is to check pressure on HPOP but not sure of procedure.
Im a little bummed that I put the money into the transmission now this..
I could use some help and guidence.
Thanks
San Diego R.B.
sd_arby is offline
post #2 of 7 (permalink) Old 04-12-2011, 10:43 PM
STILL LEARNING
Bradbilt's Avatar
Re: Changed oil ...now wont start.
What weight and brand of oil did you use?
Bradbilt is offline
post #3 of 7 (permalink) Old 04-12-2011, 10:49 PM
big nasty's Avatar
Mine does that sometimes. There is a low oil pressure sensor or something that wont let the truck run and I just keep it turning it over till it starts.
02 7.3 with a little of this and a little of that.
big nasty is offline
post #4 of 7 (permalink) Old 04-12-2011, 11:12 PM Thread Starter
I use Valvoline Premium BlueŽ Engine Oil 15/40 Diesel
sd_arby is offline
post #5 of 7 (permalink) Old 04-12-2011, 11:25 PM
95powersmoker's Avatar
How much oil did you put in? If you don't have enough oil, our trucks wont start. You need about 15 quarts.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #6 of 7 (permalink) Old 04-12-2011, 11:54 PM Thread Starter
I filled the filter before installing. Then brought to full mark on stick.
Filled from bulk barrel. Not sure of exact qts..
85 F250 4x4 6.9L w/ Banks Turbo
86 F350 4x4 7.3 Gas Guzzler
97 F250 Power Stroke 7.3L
84 Ranger 4x4 2.8L Carburetored
2000 F250 4x4 V-10
sd_arby is offline
post #7 of 7 (permalink) Old 04-13-2011, 02:00 AM
DieselAddict
j.soffa's Avatar
strange you post this, I'm having the exact same problem except I just have to crank and crank and crank and it will finally start....
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
j.soffa is offline
