D60/D50 part swap questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 51 (permalink) Old 04-12-2011, 05:05 PM Thread Starter
Dreams of owning cclb
97obs's Avatar
K I got what I feel was a pretty good deal on a D60, but it is missing a spindle and I am not sure what brackets if any it comes with. So I have a couple questions.
Will a spindle off of a TTB fit onto the D60? I know that the hubs are interchangeable but I am not sure about the spindle.
How similiar are the Track bar components of a SD D50 to the D60 stuff?
I have a few SD friends that I could use as references to build my own brackets I think if they are pretty similar. And will a SD track bar swap out for a D60 one? O'reillys sells them for a reasonable price, so I was wondering if I could go that route?
97 F250HD 4x4-3:55s
,ts 6 pos chip(tuned by [email protected]), 3'' downpipe to custom 5" straight exhaust, diy 6637 intake, Beans Stage 1s, CCV mod, Beans Non-EBPV pedestal, Stancor Relay, 6.0 IC, 16x10 American Racing Outlaw IIs, 4" Rough Country lift, 285/75/16s
97obs is offline
post #2 of 51 (permalink) Old 04-12-2011, 05:16 PM
Moderator
PsRumors's Avatar
Re: D60/D50 part swap questions
The d50 spindle will bolt to the D60 but it does not truely fit. The lip on the d50 spindle will not engage the d60 knuckle completely.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #3 of 51 (permalink) Old 04-12-2011, 05:18 PM Thread Starter
97obs's Avatar
So don't do it I guess?
97 F250HD 4x4-3:55s
97obs is offline
post #4 of 51 (permalink) Old 04-12-2011, 05:45 PM
fordnut's Avatar
it depends on the year dana 60 you have. if its a ball joint 60 the spindle is the same if its king pin its no go. the track bar setup on superduty trucks is totaly different
fordnut is offline
post #5 of 51 (permalink) Old 04-12-2011, 05:47 PM Thread Starter
97obs's Avatar
The guy says it's out of a '90, so that means kingpin I assume.
97 F250HD 4x4-3:55s
97obs is offline
post #6 of 51 (permalink) Old 04-12-2011, 06:20 PM
STILL LEARNING
Bradbilt's Avatar
Spindle will bolt on but is not quite right for your application
Track bars and mounts are COMPLETLY diffenent between a OBS and a SD
Bradbilt is offline
post #7 of 51 (permalink) Old 04-12-2011, 06:31 PM
OBS junkie
Cat_Rebel's Avatar
The spindles are close but not totally the same. The inner lip on the 60s are longer.
Grant, you can swap manual lockout hubs & bearings & that's about it between a 50 - 60.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 51 (permalink) Old 04-12-2011, 06:39 PM
sick97psd1's Avatar
Send a message via AIM to sick97psd1
I have a track bar from a Ball joint D60, but I think they are the same.
sick97psd1 is offline
post #9 of 51 (permalink) Old 04-12-2011, 06:46 PM
OBS junkie
Cat_Rebel's Avatar
The track bar from the 86-97 is the same, the 99+ are different.
RIP Will Iott
post #10 of 51 (permalink) Old 04-13-2011, 01:42 AM
04yfzkid's Avatar
04 cobra - MMR 5.0 stroker, 3.4 whipple, e-85, 30psi of boost when the belt doesn't slip
Currently converting to 78mm turbo.
96 f-250, diamond eye catless / mufflerless, DIY 6637, white rodgers 586-902, marinco mod, Denso High torque gear reduction starter, led door and dome lights, and PHP hydra for now.
04yfzkid is offline
