axle width: srw vs. drw - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-12-2011, 03:54 PM Thread Starter
I know the drums are bigger but please enlighten me on how much wider/narrow these axles are. I planned on converting my f250 to a drw pretty soon, i just dont want anything looking out of proportion. I read somewhere that a guy just mounted the dually wheels together for the rear and put the dually hubs on the front, does that sound correct?
'99 F350 V10/ZF5
stroke7.3this is offline
post #2 of 14 (permalink) Old 04-12-2011, 04:02 PM
STILL LEARNING
Bradbilt's Avatar
Re: axle width: srw vs. drw
A DRW pick-up axle is 6" wider than a SRW pick-up axle.
And you cant just put dually rims on the rear of a pickup, they will hit the springs. You either need adapers/spacers or a dually pick-up axle.
For the front, yes. Just Take off the SRW hubs and put on DRW hubs
Bradbilt is offline
post #3 of 14 (permalink) Old 04-12-2011, 04:14 PM Thread Starter
Thata what i thought, he must have had spacers, thanks for your help.
'99 F350 V10/ZF5
post #4 of 14 (permalink) Old 04-14-2011, 12:18 AM
crazed & deranged farmer
NutFarmer97's Avatar
Can you run SRW on a DRW axle? or would they be too far out past the fenders?
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #5 of 14 (permalink) Old 04-14-2011, 12:54 AM
STILL LEARNING
Bradbilt's Avatar
Do you mean take the duals off of a dually pick up and put on a single REGULAR(non-dually) wheel and tire in their place?
YES. The tires will still be tucked under the dually fender quite far
Bradbilt is offline
post #6 of 14 (permalink) Old 04-14-2011, 05:27 AM
No, I was asking if i put a dually pickup (not C&C) rear axle under my SRW f350 and ran my singles. This would only happen if i got a complete dually reat with the springs and all.
post #7 of 14 (permalink) Old 04-14-2011, 08:56 PM
STILL LEARNING
Bradbilt's Avatar
They would be 3" further out than they are now
Bradbilt is offline
post #8 of 14 (permalink) Old 05-02-2011, 08:29 PM
Off topic but not worthy of a new thread -
Can 2wd DRW hubs (front) be bolted up to a (front) Dana 60 from a SRW truck? Example - taking a 2wd F350 dually and swapping in the Dana 60 (w/RSK) from a F350 SRW.
lossscause is offline
post #9 of 14 (permalink) Old 05-02-2011, 09:16 PM
STILL LEARNING
Bradbilt's Avatar
No. the dually hub on a 2wd is part of the rotor and wheel bearing assem.
2wd rotor and hub https://www.napaonline.com/Catalog/C...+2028036#Side0
You need 4wd dually adapters from a c-n-n or aftermarket spacers
Bradbilt is offline
post #10 of 14 (permalink) Old 05-02-2011, 09:22 PM
Are these worth buying new or looking for a used set?
