Compression tester? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-12-2011, 05:52 AM Thread Starter
Compression tester?
I am looking for a compression tester. Thinking about going with harbor freights kit, but heard its kind of a pain with the fitting they give you. Is there any other cheap options to go with?
late 99 black CCSB
OUTLAW101 is offline
post #2 of 5 (permalink) Old 04-12-2011, 06:01 AM
Marc's Avatar
Re: Compression tester?
Diesel Compression Tester with Adapters | OTC Tool Manufacturer for Cars and Trucks
Its not cheap...its between $400 and $500 depending on where you can find it, but its the same guage and fitting the dealers use. IMO its worth the money, a false reading can cost a lot of money you dont need to spend.
NHRDA Region 2 Race Director
Marc is offline
post #3 of 5 (permalink) Old 04-12-2011, 06:04 AM Thread Starter
Wow, as much as i would love to have that, thats way out of my price range. Thanks for the help though, I understand that on a specialty tool its probably not the best idea to buy the cheapest. lol
late 99 black CCSB
post #4 of 5 (permalink) Old 04-12-2011, 09:17 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
I just bought this kit here. http://www.tooldesk.com/automotive/HOFTU1553-Star-Hoffman-TU1553-Diesel-Compression-Tester-Kit.aspx It has the correct adapter for 7.3PSD and an adapter for Cummins engines along with a few others. You can buy just the gauge and adapter alone for a bit less than the kit.
They are made by Star/Hoffman. The gauge is part# STR-TU-15P and the 7.3PSD glow plug adapter is STR-TU-15-22A. Because of tight clearance the glow plug adapter is made up on a hose assembly for ease of use and fitment and is setup with an O ring for proper seal. If you order just the gauge and adapter it will not come the the plastic case and you will have to order it separately. Just call and ask for it. Gauge and adapter will be in the $60-$70 range. This is why I ordered the whole kit with multiple adapters and the plastic case all in one.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #5 of 5 (permalink) Old 04-12-2011, 01:34 PM
Resident Curmudgeon
Toybreaker's Avatar
Garage
Send a message via Yahoo to Toybreaker
Get me some measurements for the glow plug threads and the threads for the gauge/hose attachment area and I can machine adaptors.... If this is something that a lot of PSN users can use I will make a bunch.....CrMo 4340 should be good for this right?
I'll make one for myself as well.... something good to have in the tool box.
2001 F250 XLT 4x4 auto
Toybreaker is offline
