spare parts to carry - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 04-11-2011, 08:04 PM Thread Starter
washingtoncoastie's Avatar
in june i will be driving the alcan from washington up to kodiak, ak. just wanted some input on what parts i should carry with me. from the research i have done the services are few and far in between most of the way. i will be driving with my wife and two kids (one being 1 month old) so i do not want to break down in the middle of nowhere and have to walk my family to the next town. here is the list of what i have compiled so far. please feel free to add anything you think i should carry with me.
fuel filters
hose clamps
spare hoses, various sizes
coolant
oil filter
oil
gpr
2 5 gallon cans of fuel
rags
stop leak for tires
2 spare tires
basic tools
cps
ipr
gear oil
trans fluid
washer fluid
shop books on dvd w/ laptop
distilled water
i know im missing some things, what are they?
washingtoncoastie is offline
post #2 of 16 (permalink) Old 04-11-2011, 08:36 PM
Old But Sexy
96 stroker's Avatar
Re: spare parts to carry
a way to fix any broken or lose wires..fuses..
96 F-350 CCLB ,auto with a couple 6 inch black aussie stacks, A Dp-tuner and AD injectors 66mm turbo and BD t.c...
Dads-01 7.3 4x4 Excursion..stock as could be
96 stroker is offline
post #3 of 16 (permalink) Old 04-11-2011, 08:59 PM
Patrick Feeley's Avatar
Lets see (this is what I have in my tool box)
CPS (multiple)
Filters
idler pulleys (grooved and smooth)
tensioner
fuel pump
banjo bolt gaskets
belts (multiple old belts)
valvecover gasket
Under valvecover harnesses
External VC Harness repair kit and pins
Glowplug relay
Hoses
IDMs (multiple)
O-rings for HP oil lines and plugs
Fan Clutch wrench set
pump pulley puller (power steering and vacuum pump)
Spare wiper arms and blades
Other things maybe to consider that you (or I) haven't listed:
Vacuum pump
Injector o-rings
ICP
PCM
Just throwing stuff out there! Cheers!
Patrick Feeley is offline
post #4 of 16 (permalink) Old 04-12-2011, 12:42 AM
Built not Bought
1990 Scorpion's Avatar
I would recommend buying extras of all your important fuses, it's the simplest of fixes but say you blow one out it leaves you up **** creek without a paddle.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #5 of 16 (permalink) Old 04-12-2011, 01:18 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
penetrating oil. electrical tape. duct tape. some wire. flashlight, air sourse/ 12v tire inflator, bulbs espically an extra set of headlights. tire valve cores. u joints, grease gun and grease im sure theres more
Refugee
pstroke96 is offline
post #6 of 16 (permalink) Old 04-12-2011, 01:51 AM
Fuses and the big relays that are in the fuse panel under the hood. Had one of these go out and leave me stranded. Depending on what kind of filter setup you have, maybe an extra filter. Spare Vacuum line and fuel line?
I would check and see what phone service provider has the most service along that route. If you dont have a CB, get one for the drive and get it on channel 17 so you can talk to truck drivers if needed. It might be worth it to look into one of the GPS tracking devices that Sprint Offers. You can send out a help signal from anywhere. Ill bet enough people travel that road though that you wont have a huge issue getting a ride into town if you need a part.
1997 F-350 Crew Cab Long Bed SOLD
2008 F-350 CCLB King Ranch- Spartan Tuned, Exhaust, Intake
Flippincgfighter is offline
post #7 of 16 (permalink) Old 04-12-2011, 01:51 AM
Oh and maybe if you could borrow a scanner for the trip to read codes if something does go wrong?
post #8 of 16 (permalink) Old 04-12-2011, 01:52 AM
pstroke96's Avatar
channel 17? i thought all the cool kids ran channel 19. 9 is the emergency channel though
Refugee
post #9 of 16 (permalink) Old 04-12-2011, 02:02 AM
OBS F350's Avatar
Straps/chains just in case, and you could definitely help someone out with them if need-be, maybe even a come-a-long.
96 F350 zf-5, Rosewoods, 6637, mbrp, southbend, autometer, Rough Country. SOLD
08 f250 auto, dpf/egr delete, afe intake, Gearhead tunes
:, cold side pipe and cfm+ intake elbow.
OBS F350 is offline
post #10 of 16 (permalink) Old 04-12-2011, 02:30 AM Thread Starter
Good stuff guys. I have a cb. Got a gps, tow straps, and enough flash/flood lights to light up about a 1/4 mile! I knew I was forgetting a few major things and the fuses was what I couldn't think of. Gonna get some spare fuel line. Keep it comming!
