OBS to Excursion Axle/Brakes Swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-11-2011, 01:16 AM Thread Starter
USASF Retired
halo's Avatar
This may be dumb.... but I noticed my friends Excursion has rear disk brakes. Would it be possible to use the same setup on our OBS'? I think his is a 97 or 98.
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #2 of 6 (permalink) Old 04-11-2011, 01:21 AM
Just another OBS addict
rancherstroker6's Avatar
Re: OBS to Excursion Axle/Brakes Swap
It would have to be at least a 99 excursion. You wouldn't be able to use that axle without major work, meaning it's not bolt in. The axle widths and spring perch widths are different. However, many have put SD/Excursion axles in OBS trucks, one being Garrett (weareweird69). It would also require the front axle to be swapped in order to keep axle widths the same.
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #3 of 6 (permalink) Old 04-11-2011, 01:23 AM
They didnt make an excursion in 97, I think they started making them in 2000?
Yes your can swap axles in, basically you will have to swap a new front axle in there to and run a rsk with SD springs up front. There will prolly be more that will be need to be done.
02 f250
countryboyrob is offline
post #4 of 6 (permalink) Old 04-11-2011, 01:23 AM Thread Starter
USASF Retired
halo's Avatar
So we could not use the rear disk brakes on our axles?
halo is offline
post #5 of 6 (permalink) Old 04-11-2011, 01:24 AM
Simple answer: No.
02 f250
post #6 of 6 (permalink) Old 04-11-2011, 09:01 PM
STILL LEARNING
Bradbilt's Avatar
They are 8 on 170mm bolt pattern. OBS have a 8 on 6.5 bolt pattern, you decide
Bradbilt is offline
