Has anyone had a 10.25 rear end rebuilt - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-09-2011, 09:07 PM Thread Starter
444CuiOBS's Avatar
Hey guys, have you ever had your rear diff rebuilt and roughly what did you spend on it? I have a range of quotes...from $650-$2,000
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #2 of 10 (permalink) Old 04-10-2011, 07:46 AM
Re: Has anyone had a 10.25 rear end rebuilt
Well we need to know what's getting replaced.
Got4wd is offline
post #3 of 10 (permalink) Old 04-10-2011, 07:07 PM Thread Starter
444CuiOBS's Avatar
Well yeah, thats just it, I don't and wont know until they tear into it.
post #4 of 10 (permalink) Old 04-10-2011, 07:34 PM
7.3 Enthusiast
91turbogsx's Avatar
I'm rebuilding mine at the moment. It's a 10.5 but shouldnt really matter price wise since they are about the same. Anyways I'm replacing all bearings and seals, and installing a trac-lok. I'm at about $850 in parts already and if I had to do the gears as well you can add probably another $3-400. That's just parts alone mind you since I'm doing it myself.
Your $650 quote was most likely replacing carrier and pinion bearings only. The $2000 quote is most likely new carrier, all bearings, and a ring and pinion set.
'02 F-350 4x4 Black RC/LB
4" Lift with 35's. OUO Traction Blocks
20x10 Fuel Throttle's
Lots of deleted parts...
Custom fuel system w/ Strictly Diesel RR
Dieselsite Adrenaline HPOP
DI Up-Pipes
DP-Tuned
and more...
91turbogsx is offline
post #5 of 10 (permalink) Old 04-10-2011, 08:04 PM Thread Starter
444CuiOBS's Avatar
91turbogsx, thanks for the reply. I'll probably just rebuild the entire rear end...still cheaper than a new truck!
post #6 of 10 (permalink) Old 04-10-2011, 08:46 PM
STILL LEARNING
Bradbilt's Avatar
Just buy another axle with the right gear ratio. they are between 100-400 used
Bradbilt is offline
post #7 of 10 (permalink) Old 04-10-2011, 09:18 PM
PSN nerd
I rebuilt mine, with an trutrac it was like $800 in parts I can do a gear swap and setup in 4-6hrs so I could see $1200-1400 installed
Like what brad said you can find a used one, but they can be on there last leg when you get it and not know it.
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #8 of 10 (permalink) Old 04-10-2011, 10:27 PM Thread Starter
444CuiOBS's Avatar
Yeah good point on just finding another complete rearend. I guess I'll just have to wait and see how shot mine is. Thanks for the replies guys
post #9 of 10 (permalink) Old 04-11-2011, 01:48 AM
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Paid $550 for my True-Trac $500 for my Yukon ring/pinion and bearing/seal kit + $275 for install.
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #10 of 10 (permalink) Old 04-11-2011, 10:09 PM
Needing Carbon Credits
Mine ran about $1500. Nice part was 4 wheel parts had to install a new r&p on their dollar since they f'ed up the old one.
05 F350 FX4 - Deleted and Exhausted
jmontes is offline
