Little Help getting Transfer Case off Tranny!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-09-2011, 03:32 AM Thread Starter
Hey Guys,
Need your assistance and suggestions. Here's the deal. Trying to disconnect the transfer case from the tranny (ZF-5) on '96 CCLB 4X4 F 350 while still on the truck. So I have undone the 6 bolts that hold the transfer case to the ZF-5, unhooked the driveshafts, removed the tranny cross member, exhaust. Have the transfer case on a tranny jack with the transmission supported with a nylon strap between the frame rails so it will not fall too far toward the ground, once they come apart.
I can not seem to separate the two?? Currently have a 1 ton chain come a long hooked to the rear drive shaft flange and rearend. Just to put some rearward tension on the TC.
What am I missing?? Should it be hard to pull apart I though once you had the bolts undone it would separate on it's own??
I am afraid to really put the power to the come a long for fear I've missed something...
Suggestions please..
Tia,
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #2 of 14 (permalink) Old 04-09-2011, 03:38 AM
Stroken it 7.3,6.0,6.4
weekendwarriorfsw32's Avatar
Re: Little Help getting Transfer Case off Tranny!!
You should be able to wiggle it up and down to pull it off the rear trans shaft.
08 F 450 King Ranch 6.4
Elite Race trans, Spartanized, ARP, Icon 4.5 on 35's, RDP boots, HID'S, OUO ladder bars, 3" I/C pipe
04 X 6.0
08 tow mirrors, ARP studs, RDP boots.
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB holding on for dear life @40+psi, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots
weekendwarriorfsw32 is offline
post #3 of 14 (permalink) Old 04-09-2011, 03:44 AM Thread Starter
Ok so it's not like I've missed anything...it's just being a bit temper....mental and not wanting to let loose?
jrc
JCart is offline
post #4 of 14 (permalink) Old 04-09-2011, 03:47 AM
STILL LEARNING
Bradbilt's Avatar
There is no need for a chain hoist to seperate the two. If you would of left the trans cross member in it would actually make things easier.(keeping the trans stationary while wiggling the t-case)
I'm sure corrosion is a big part in holding the two together
Bradbilt is offline
post #5 of 14 (permalink) Old 04-09-2011, 03:50 AM
Nope your not missing anything as long as you got all the bolts out.
04 X 6.0
post #6 of 14 (permalink) Old 04-09-2011, 03:53 AM
Its been awhile but for some reason 6 bolts sounds a little on the light side?
nvm guess six is right
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
BlindViper is offline
post #7 of 14 (permalink) Old 04-09-2011, 03:54 AM Thread Starter
Hey Brad,
Thanks I was just thinking of putting it back on (trans X member)...only reason I took it off was the tranny is coming out too and was worried the T Case would wanna flip the T jack on it's side if I kept them togethers as well it was easier to get at the T C bolts....
thanks for the suggestions....back outside before it's too dark..
thanks again,
jrc
JCart is offline
post #8 of 14 (permalink) Old 04-09-2011, 03:56 AM Thread Starter
yes 8 not six and they are all out....hahaha
JCart is offline
post #9 of 14 (permalink) Old 04-09-2011, 04:16 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
give it a few hits with a rubber mallet or deadblow hammer, it should pop apart if the wiggle jiggle doesnt do it
Refugee
pstroke96 is offline
post #10 of 14 (permalink) Old 04-09-2011, 05:28 AM
oilfield trucker
zpilgeram's Avatar
Although I would assume you have I noticed you did'nt mention anything about unhooking the 4x4 linklage. You did unhook that, rite ? Like said above, if everything is unhooked it should seperate. Also, I've found once you get the transfer case loose, gently slide it away from the transmission about an inch, so the xfer case comes out of the dowel on the back of the xmission. Then you can let the xfer case rotate down, it will then be about an inch or two off the floor then you simply slide it the rest of the way off the output shaft of the xmission and let it drop down. That way you dont have to try and steady it on a jack since they're so lopsided.
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
