Ran out of fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-08-2011, 09:36 PM Thread Starter
Question Ran out of fuel
Hasn't run since. I've worked on it every day for the past 30 days. Been using all the great help & ideas in this forum. But still no start. I really need my truck running. Any ideas will be appreciated.
To date I've replaced the fuel pump, new filter, blew out the return & supply lines & removed the injector device attached to the fuel filter & cleaned it. It cranks w/ white smoke evident. I got one or two pops today with heavy cranking but no start. Ive been approaching the problem as trash in the fuel system.
kfredx is offline
post #2 of 18 (permalink) Old 04-10-2011, 02:42 AM
DieselAddict
j.soffa's Avatar
Re: Ran out of fuel
SOunds like a pain so far... Make sure your fuel bowl is full of fuel, also make sure your HPOP res is full. If you're getting white smoke that means you're getting fuel. How cold has it been? All fuses intact? Tried jumping the GPR for 30 seconds then try cranking? Unplug your ICP try cranking.
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
j.soffa is offline
post #3 of 18 (permalink) Old 04-10-2011, 02:44 AM
Re: Ran out of fuel
Do you get a WTS light?
madpogue is offline
post #4 of 18 (permalink) Old 04-10-2011, 04:03 PM Thread Starter
Re: Ran out of fuel
No
1997 F350 Turbo, 7.3L, 5-Speed Manual, 4X4, Dually.
kfredx is offline
post #5 of 18 (permalink) Old 04-10-2011, 04:07 PM Thread Starter
Re: Ran out of fuel
Hpop res filled, It's summer in N.O., Checked the fuses & relays. Thanks for the next steps. I was stumped.
kfredx is offline
post #6 of 18 (permalink) Old 04-10-2011, 05:21 PM
Bugman's Avatar
Re: Ran out of fuel
The first thing to check when you don't get the wait to start light is the #22 fuse under the hood. Don't just look at it but test. If it is bad then unplug the fuel heater line on the drivers side of the fuel filter housing it is the spade type connector about in the middle. Replace the fuse and see what happens.
Bugman is offline
post #7 of 18 (permalink) Old 04-10-2011, 07:04 PM
95powersmoker's Avatar
Re: Ran out of fuel
Originally Posted by kfredx View Post
No
Check your fuses... Especially fuse 22.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #8 of 18 (permalink) Old 04-10-2011, 07:46 PM
Re: Ran out of fuel
^^^^ And DON'T just replace it. Common cause of fuse 22 failure is the fuel heater shorting out. You should disconnect it first before replacing the fuse; otherwise it'll just blow another one.
S-WAG - when the fuel ran dry, the fuel heater was still running but with no fuel to heat, it overheated and shorted out, blowing the famous #22.
Hate to say it, but that should've been the first clue to follow, rather than throwing all those parts at it.
madpogue is offline
post #9 of 18 (permalink) Old 04-12-2011, 01:39 AM
It likes 4400 rpm!
Re: Ran out of fuel
Also plug it in for ####s and giggles
1986-FORD F-250, 4X4, T-19,6.9 bored.020 MANY MODS, and broke again
1995-F-350, ext cab, DRW, 2WD, 291,xxx miles , ZF5, MODS:chopped exhuast, FPR shimmed, 6637, gutted ebpv
dyoung14 is offline
post #10 of 18 (permalink) Old 04-12-2011, 01:51 AM
Re: Ran out of fuel
That won't fix a blown fuse, or whatever circuit problem has caused the WTS light to go off. Without the WTS light, there's a circuit open and that's why the truck's not starting.
madpogue is offline
