Stumble/miss on throttle jab.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-08-2011, 02:21 AM Thread Starter
Work in progress!
Big Calo's Avatar
We just replaced a pigtail and UVH on my brothers 95 and now it idles fine and runs fine but when I stab the throttle it stumbles for a split second then picks right up. Doesnt matter where I jab it at from idle to 2500 it does the same thing. A little stumble then just purrs away. Everything is smooth aside from that. I can put his chip on high idle ~1200 and its fine no miss or anything and stab the throttle and stumble then fine.
Mods are intake, exhaust, chip.
A search turned up CPS or possibly an IPR? Anyway to check for sure on either of these?
Thanks in advance.
Southern lights!!!
My big truck Early 99
(Currently trying to unfinance!)
Foil delete
5" SS Magnablows Straight Pipe
Adrenaline HPOP
AFE Stage II w/Progaurd 7
D66 Turbo
Autometer Guages
Beans 6po chip
Full Force 250/100s
CCV mod
Big Calo is offline
post #2 of 2 (permalink) Old 04-08-2011, 12:15 PM
Demon Dually
speeddemon31176's Avatar
Re: Stumble/miss on throttle jab....
You can check the IPR by removing and cleaning or replacing it. The only way to truly verify a CPS issue is to replace it and see if the symptoms go away.
speeddemon31176 is offline
