4 x 4 Not Engaging - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-08-2011, 02:04 AM Thread Starter
4 x 4 Not Engaging
97 7.3 Automatic: 175K. Just got it a couple of months ago; been sitting for 3 years. Ran rough, bad IDM. Before replacing IDM: put it in 4 x 4 mode & drove it many times across my farm in 1st @ high RPM. Never had it on the road & never above 25 MPH.
After replacing IDM: runs smoothly, but 4 X 4 will not engage. Did a search, but could not find anything. Is there a fuse somehow connected to the 4 X 4?
Thanks
Tater50 is offline
post #2 of 9 (permalink) Old 04-08-2011, 02:05 AM
STILL LEARNING
Bradbilt's Avatar
Re: 4 x 4 Not Engaging
Are you saying it has an electric transfer case? never seen or heard of one in anything other than a 1/2 ton
Bradbilt is offline
post #3 of 9 (permalink) Old 04-08-2011, 02:07 AM
One of a kind
PSD-BLACK-CLOUD's Avatar
My 97 had auto lock hubs. Is that what yours has. You couldnt turn them to engage them you just shifted in in the cab then were good to go.
2010 F-350, Auto,4X4, 4dr long bed, SCT/Gearhead, S&B, High Idle,Guages:boost,egt,trans, 2.5" Leveling Kit/Track Bar, PMF bars, 325-60-20's on 20x10 XD Revolvers
PSD-BLACK-CLOUD is offline
post #4 of 9 (permalink) Old 04-08-2011, 06:28 AM
Have you tried 4-low?
Were you at a full stop when you switched to 4-high?
If you have an assistant, see if the front driveshaft, or either axle shaft, turns when you move it down the road with the truck in 4-high.
And yeah, two details that should always be specified when opening any 4x4 related thread - * electric or manual 4x4?, and * OEM centrifugal auto lock hubs or manuals?
madpogue is offline
post #5 of 9 (permalink) Old 04-10-2011, 12:52 PM Thread Starter
Full Stop; in neutral; shift lever in the floor; and I cannot swear that the 4 x 4 was working initially; it felt as if it were in the 4 x 4. I am new to 4 x 4's; so that is an excellent point; I will mark the shaft w/paint to see if there is any rotation.
Tater50 is offline
post #6 of 9 (permalink) Old 04-10-2011, 12:59 PM
bluedge8's Avatar
i'm betting auto hubs and that's the problem, one or both are froze up. also how are you determining that you do or don't have 4x4?
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #7 of 9 (permalink) Old 04-12-2011, 11:24 AM Thread Starter
Been real busy have not be able to reply: thanks for the responses. Not being sarcastic: I was moving the truck the other day in muddy conditions & the rear wheels were spinning & the front were stationary. This is a farm truck & probably will never see the road & all tires are near bald; but as I tried to move I only felt the rear spinning.
Auto hubs: is there a way to unfreeze these?
Tater50 is offline
post #8 of 9 (permalink) Old 04-12-2011, 11:39 AM
bluedge8's Avatar
no problem, some people mis diagnose right from the beginning. yeah you can work on them some do a search for them, biggest thing is that they take almost no grease when going back together b/c they will bind with too much grease. Most guys just go to manual hubs, especially as a dedicated farm truck
bluedge8 is offline
post #9 of 9 (permalink) Old 04-12-2011, 03:17 PM
STILL LEARNING
Bradbilt's Avatar
Just go to a Junk yard and get a used set of manual hubs. Just make sure you get the wheel bearing lock nuts too, they are differnt than auto hub ones
Bradbilt is offline
