Which is fried IDM or ECM? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-08-2011, 12:40 AM Thread Starter
enemyofgore's Avatar
Exclamation Which is fried IDM or ECM?
On my 97 7.3L I have a chip from elite diesel and it may or may not have fried either my ECM or IDM (or, god forbid, both), it had a flame out and will turn over but the glow plug light will not come on, so which went out? I have found a lot of IDMs online but I cannot really find any ECMs so I don't know which is dead and finally if it is the ECM, where do I find one that I can just plug straight into the truck? I need help FAST I have to have this truck by next Saturday, thanks to those who post.
enemyofgore is offline
post #2 of 15 (permalink) Old 04-08-2011, 12:41 AM
Re: Which is fried IDM or ECM?
Check the connection where the chip plugs into the PCM.
02 f250
countryboyrob is offline
post #3 of 15 (permalink) Old 04-08-2011, 12:47 AM
pmasterson's Avatar
By "glow plug light" do you mean the "wait to start" light? If so check the #22 fuse in the underhood fusebox.
1995 F350 CCLB 4X4
TW tunes, GS gauges, Aeroforce Interceptor
3" RSK w/SD springs & Bilsteins
DIY 6637, 3" DP to straight exhaust
pmasterson is offline
post #4 of 15 (permalink) Old 04-08-2011, 12:53 AM Thread Starter
yeah sorry, I do mean the wait to start light, and I have checked both the #22 fuse and the chip connection, I have tried checking almost everything that I can, which is why I am pretty sure it is one of those computers, I called elite and told them everything but they suggested I go to a certain website and that place only sold IDMs, it just doesn't make much sense to me for the IDM to have anything to do with the wait to start light, the only thing is something I heard about some glow plug relays and I do not know where those are or how to check them.
post #5 of 15 (permalink) Old 04-08-2011, 01:08 AM
blageurt's Avatar
This site ?.....http://www.autocomputerexchange.com/Makes/Ford/6
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #6 of 15 (permalink) Old 04-08-2011, 01:49 AM
95powersmoker's Avatar
Were your keys in the ignition when you installed the chip?
Did you make sure to clean the PCM?
Have you actually replaced the #22 fuse or just visually inspect it?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #7 of 15 (permalink) Old 04-08-2011, 02:31 AM Thread Starter
I tested the fuse with a fuse tester, cleaned the pcm before installing the chip, and yes that is the site
post #8 of 15 (permalink) Old 04-08-2011, 02:32 AM Thread Starter
and the keys were definitely not in it or on when I put the chip in, also I disconnected both negative battery cables
post #9 of 15 (permalink) Old 04-08-2011, 02:32 AM
Have you taken the chip out and tried to start it?
James
post #10 of 15 (permalink) Old 04-08-2011, 02:36 AM Thread Starter
actually the elite guy told me to go to some ebay store at least now I know where to find a new ecm thanks blageurt
