97 F250 HD Rear Hub clunk - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-08-2011, 12:04 AM Thread Starter
444CuiOBS's Avatar
Hey guys,
Looks like rear end trouble, I have yet to take it apart, just looking for opinions.
Here's what I got:
I originally noticed a clunk from the rear while shifting from D to R and figured I was due for u joints, a couple weeks later I started to hear a slight squeal like worn brake shoes. A few days after this began I started hearing ticking especially on take off and taking corners. (still thought U joint)
I had my buddy shift from D to R while I took a look under the truck. When the truck is shifted while holding the brake I get a clunk from what appears to be the drivers side hub, but I also watch the shaft going into the diff and can see an unusual amount of play leading up to the clunk. I get slight vibration around 40-50mph also.
Either way this looks and sounds spendy.
So, what you guys think?
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #2 of 10 (permalink) Old 04-08-2011, 12:50 AM
STILL LEARNING
Bradbilt's Avatar
Re: 97 F250 HD Rear Hub clunk
Bad crush sleeve. Semi common on a 10.25
Bradbilt is offline
post #3 of 10 (permalink) Old 04-08-2011, 01:52 AM Thread Starter
444CuiOBS's Avatar
Thanks for the reply Diesel Brad. Any idea if thats a spendy fix?
post #4 of 10 (permalink) Old 04-08-2011, 02:02 AM Thread Starter
444CuiOBS's Avatar
Looks like a diff tear down is on the way..
post #5 of 10 (permalink) Old 04-08-2011, 02:04 AM
STILL LEARNING
Bradbilt's Avatar
They make a crush sleeve eliminator. That is as long as your ring and pinion is not FUBAR
Bradbilt is offline
post #6 of 10 (permalink) Old 04-08-2011, 02:16 AM Thread Starter
444CuiOBS's Avatar
Yeah i was ready about the eliminator. Do you know if the crush sleeve can just be replaced easily or does the pinion need to come out? I have maybe 10-15 miles on it since I noticed the noise....guess it could've been too late by them, hopefully wont need a new ring and pinion.
post #7 of 10 (permalink) Old 04-08-2011, 02:20 AM
STILL LEARNING
Bradbilt's Avatar
crush sleave goes in behind seal. but it cant just be replaced. It needs to be crushed to the correct amount, back lash checked, ........etc
Bradbilt is offline
post #8 of 10 (permalink) Old 04-08-2011, 10:54 PM Thread Starter
444CuiOBS's Avatar
Well my truck is going in this Wednesday, I dont have time to rebuild the diff myself. I'd probably save $500+ in labor though. The worst part about this is that I'll be trailering my truck behind a duramax, ouch. I'll update with whatever they find.
post #9 of 10 (permalink) Old 04-21-2011, 10:56 PM Thread Starter
444CuiOBS's Avatar
Well well well...I guess I got excited for nothing. The rear end is perfect. The u joints were shot. I replaced both ends on the drive shaft, the roller bearings rusted solid and I actually had a broken lobe on the rear; lucky it didn't drop out on the road.
post #10 of 10 (permalink) Old 04-22-2011, 12:23 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
definatley lucked out on that one, but all thoes signs do point to u joints, that would be the first thing to check in the future, there a cheap and easy fix compaired to most things
Refugee
pstroke96 is offline
