Boost Leak ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-07-2011, 11:57 PM Thread Starter
Wardy70's Avatar
Boost Leak ?
Ive owned my truck for over a year, the truck seems to have a good bottom end power but mid range is lacking. The truck is completely stock except a TS chip in it. I tested for a boost leaks today and I definately have a leak but unable to locate it. It sounded like it was coming from intake plenums but after spraying soapy water all over I still cant find it. Any ideas would be great thanks.
Wardy70 is offline
post #2 of 8 (permalink) Old 04-08-2011, 01:47 AM
95powersmoker's Avatar
Re: Boost Leak ?
Check the boots in the middle of the valley attached to the spyder...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 8 (permalink) Old 04-08-2011, 02:03 AM Thread Starter
Wardy70's Avatar
Re: Boost Leak ?
I sprayed those down also with soapy water and no leaks, I can hear it I just can't find it.
97 auto 333000 miles
TS chip,transgo tugger, billet converter,3" downpipe, diy intake, Super 66 turbo, Rosewood stage 1s. Modified hpop.
97 5 speed 250/100 injectors, 3"downpipe, Tony Wildman tunes, D60 conversion. Sold
99 Auto 238/80 full force injectors, modified 17 hpop, billet d66 turbo, beans sump in tank
Wardy70 is offline
post #4 of 8 (permalink) Old 04-08-2011, 02:28 AM
powerstroker6.0
StrokerSmoker01's Avatar
Re: Boost Leak ?
I'm fighting a boost leak as well man egts hit 1300 with a empty horse trailer tons of power just high egts
05/6.0/ccsb/fx4/lariat/Egr delete/Sct/Airdog2 165 gph/Powermax/6.4 banjos/5 inch mbrp/120k/SOLD
96/f250/7.3/5spd/rclb/35s/ts by beans/330k/SOLD
01/3500/6spd/4x4/Fully built/Riding on 22.5s/313k
StrokerSmoker01 is offline
post #5 of 8 (permalink) Old 04-08-2011, 02:30 AM
Re: Boost Leak ?
An old trick for finding exhaust leaks is to run a piece of tubing around where you think it is and have the other end of the tubing up to your ear...
Might be worth trying if you can't find if with the soapy water.
James
post #6 of 8 (permalink) Old 04-08-2011, 03:13 AM Thread Starter
Wardy70's Avatar
Re: Boost Leak ?
I don't have any guages so I really can't tell you what the egt's are. In stock tune the truck is pretty pathetic. With the tuner it doesn't run to bad. I'm just trying to get some stuff diagnosed while I have another set of wheels. I have a downpipe sitting here for it but want to find this first. I have a old stethoscope maybe I will give that a try.
Wardy70 is offline
post #7 of 8 (permalink) Old 04-09-2011, 02:08 AM
gnxtc2's Avatar
Re: Boost Leak ?
Make an adapter to fit on to the turbo inlet so you can use compressed air.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #8 of 8 (permalink) Old 04-09-2011, 08:29 AM Thread Starter
Wardy70's Avatar
Re: Boost Leak ?
That is how I was checking for leaks.
Wardy70 is offline
