Turbo Removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-07-2011, 09:27 PM Thread Starter
DieselAddict
j.soffa's Avatar
Turbo Removal
How do you get the bolt out that is between the turbine housings? The one that connects to the uppipes. I have spent the last 2 hours trying to get at that bolt so I can switch out my turbo. There isn't any room to stick anything in there. I can get a 15mm wrench in but there is no room to twist it. Tried a universal but there isn't enough room to get a clean contact with the bolt...
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
j.soffa is offline
post #2 of 18 (permalink) Old 04-07-2011, 09:34 PM
wrenchturner250's Avatar
Re: Turbo Removal
if you are talking about the two on the flange then is used a 15mm short wrench... to break it loose I used a cheater wrench to help its a pain lots of pb blaster and you should get it... it takes time and a lot of wrench twisting and you get about a half a turn maby each time
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #3 of 18 (permalink) Old 04-07-2011, 09:41 PM Thread Starter
DieselAddict
j.soffa's Avatar
Re: Turbo Removal
well it looks like a trip to the hardware store then for a short wrench... thanks
j.soffa is offline
post #4 of 18 (permalink) Old 04-07-2011, 09:57 PM
Moderator
PsRumors's Avatar
Re: Turbo Removal
not to hijack but.....
Does a non-ebpv pedestal make removal and install easier?
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #5 of 18 (permalink) Old 04-08-2011, 11:36 AM
black974door's Avatar
Send a message via AIM to black974door
Re: Turbo Removal
yes it does
'97 f-350 4door long box
hybrids!ll
Trans done by hollywood transmissions!!
ts-6pos chip with gearhead tunes
3"dp to a 7" cat stack!!!
diy e-fuel
egt, trans, and boost on overhead pod
cone filter....
need toinstall:
intercooler
s372
LOOKING FOR:
17* hpop
for sale: 1965 GMC shortbed step side. PM for detail, pics and price
black974door is offline
post #6 of 18 (permalink) Old 04-08-2011, 01:07 PM
woodduck97's Avatar
Re: Turbo Removal
Yes allot easier. You can pull the turbo in half the time with a deleted pedestal. I highly recomned getting one.
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #7 of 18 (permalink) Old 04-08-2011, 01:23 PM
Moderator
PsRumors's Avatar
Re: Turbo Removal
I have one....just trying to decide if I want to pull the turbo to replace it, have it don't by someone else or wait until there is a leak to replace it.
PsRumors is offline
post #8 of 18 (permalink) Old 04-08-2011, 03:35 PM
Re: Turbo Removal
More tools yaaay....what I did was head to sears and get a set of stubby gear wrenches. One end is like a box end but has a ratcheting mechanism other end of wrench is standard open end. They are awesome for tight quarters and the ratchet mechanism eliminates having to reset the wrench.
I think Swamp's Diesel site has a write up on turbo removal install which is good iirc. Think it was them that suggested using an elastic band to hold up the rear pedistal bolts on install. Also to use a piece of plastic (like a chunk of clean oil jug) to sandwich between pedistal and block o-rings to keep in place while centering pedistal on install. This will keep those pesky o-rings in place until you get pedistal bolts started then you just gently slide out the plastic.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #9 of 18 (permalink) Old 04-08-2011, 03:40 PM
woodduck97's Avatar
Re: Turbo Removal
Not enough room for a rachet wrech in there...
post #10 of 18 (permalink) Old 04-08-2011, 03:52 PM Thread Starter
DieselAddict
j.soffa's Avatar
Re: Turbo Removal
well the turbos out after a full days worth of work.... now I have to gut the ebpv and the pedestal, clean up the engine, put the new plenums on, and reinstall everything...
j.soffa is offline
