97 powerstroke not starting help!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-07-2011, 05:04 PM Thread Starter
I have a 97 f350 7.3, i pulled the passenger head because it had a glow plug stuck, i decided to put new valve springs in new pushrods, new glow plugs, apr head studs torqued to 125lbs, and a set of reman stage II Injectors. I have no chip yet... i cranked on it until oil came out of the front oil plugs like i was told, then cranked and cranked now ive got white smoke (fuel) but she still will not start.. this truck has been sitting for around 2 1/2 months waiting for parts and what not.. any suggestions on what im doing wrong?
thanks
Ben
Its about 50 degrees out today but i wouldnt think that would bother it
ben97 is offline
post #2 of 12 (permalink) Old 04-07-2011, 05:07 PM
95powersmoker's Avatar
Re: 97 powerstroke not starting help!!
White smoke is good, Unburnt fuel.
It might take 5 or so 15-20 second cranking cycles to start...
Have you checked the HPOP res to make sure its still got oil?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 12 (permalink) Old 04-07-2011, 05:09 PM Thread Starter
ive done well over 5 cranking cycles, and no i havent checked the hpop res... i will do that right now...
ben97 is offline
post #4 of 12 (permalink) Old 04-07-2011, 05:47 PM Thread Starter
oil res is full still wont start... im gonna dig into the wiring see if i missed something... there is a sensor right below the thermostat housing should there be a wire hooked up to it if so i cant find and extra wire? but any more suggestions would be great!!
ben97 is offline
post #5 of 12 (permalink) Old 04-07-2011, 05:59 PM
Check the fuse #22 in the fuse box underhood.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #6 of 12 (permalink) Old 04-07-2011, 07:19 PM Thread Starter
ok shes starting to fire but wont run... valve covers are off does that make a difference?
ben97 is offline
post #7 of 12 (permalink) Old 04-07-2011, 07:22 PM
Nope. You're tach is moving correct? The fuel bowl is full of fuel?
James
post #8 of 12 (permalink) Old 04-07-2011, 07:50 PM Thread Starter
yes and yes, its right there, someone told me foam in the oil would mess with the injectors?
ben97 is offline
post #9 of 12 (permalink) Old 04-07-2011, 09:57 PM
Foam? Meaing air in the system still............ Is my guess.
Get it running them bring them rpms up and then beat the piss out of her.
02 f250
countryboyrob is offline
post #10 of 12 (permalink) Old 04-08-2011, 01:46 AM
Not sure what you mean by foam... Shouldn't be any unless you add an additive to your oil.
Check all your fuses?
James
