Dana 60 Swap spring problem - panic - need help asap Sky Mfg. kit etc.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-06-2011, 08:42 PM Thread Starter
danielzink's Avatar
Hey all,
We're in the middle of a Dana 60 swap into my 97 OBS.
It's going on a Sky Mfg. RS kit.
Kit is mounted as per instructions - my mechanic called me and says the front springs are 5 inches too long.
He says the (new) shackles are flat against the frame and it will move the axle back as well.
My invoice for the springs reads 2C3Z-5310-HA
Everything I read puts this as a V code spring - anyone have any ideas ?
Thanks, Dan
1997 F-250 Powerstroke, 4x4, D60, RSK, V&B's, 35" BFG ATA's on 16x10's, 6637 DIY Intake, Swamps IDM Mod, 3" DP, 4" single exhaust, Beans E-Fuel, Intercooled, Rosewood 160/80's, T4 S366SXE, Irate 3" Plenums, Terminator T500, Tony Wildman Tunes, Gauges (Pyro/Boost/Trans).
danielzink is offline
post #2 of 9 (permalink) Old 04-06-2011, 08:46 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: Dana 60 Swap spring problem - panic - need help asap Sky Mfg. kit etc..
try calling paul at complete performance Complete Performance he sells rsk kits and can help you out
Fordfreak4life is offline
post #3 of 9 (permalink) Old 04-06-2011, 09:18 PM
psdmike's Avatar
If your useing the stock springs on a OBS the SKY kits works in the factory location. But if your useing V code springs from a Super Duty they are about 4" longer then the OBS. The Sky bracket has to be moved about 3 3/4 inches to the end of the frame.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #4 of 9 (permalink) Old 04-06-2011, 09:24 PM
Krause's Avatar
, pretty sure you have to move the front main bracket forward when using SD springs. Call Cary and ask him, he will know exactly whats up. Google Ct performance Inc, or go to vendor ally and find his contact info.
96 XLT ECLB. 6.0 intercooler. 4" aero turbine, gearhead tunes. Coolant filter & CCV mod. SD Dana 60 3.73 3.5 RSK V-codes, 35 inch toyos, 18inch M/T classic locks. 260000Km
Krause is offline
post #5 of 9 (permalink) Old 04-06-2011, 09:34 PM Thread Starter
danielzink's Avatar
Thanks for all the replies guys.
Hopefully moving the bracket forward is the solution.
I hate calling someone I didn't buy something from for advice...I kinda feel like a jerk....ya know ?
Thanks again !
Dan
post #6 of 9 (permalink) Old 04-06-2011, 09:46 PM
Krause's Avatar
Swallow the pride, or do it twice.. That said, there is an article in the library at the top on the home page which outlines all the measurments for the bracket being moved forward. here is the link,
Reverse Shackle Kit Articles - PowerStrokeNation
Krause is offline
post #7 of 9 (permalink) Old 04-06-2011, 09:51 PM
psdmike's Avatar
3 3/4" Is what i did mine at and it worked. Good luck with your project.
psdmike is offline
post #8 of 9 (permalink) Old 04-09-2011, 01:11 AM
psdmike's Avatar
Did you get it to work?
psdmike is offline
post #9 of 9 (permalink) Old 04-09-2011, 03:43 AM Thread Starter
danielzink's Avatar
Yep.
As stated by others - I sucked it up and called Cary. He was very generous with his time. We moved the brackets forward and it's in the final stages of assembly. Will post pics when done.
I appreciate everyones help - thanks again.
I'll try to keep my newbie panic attacks to a minimum
Dan
