steering columns - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-06-2011, 03:56 PM Thread Starter
steering columns
I was wondering if I take my cruise control tilt wheel column out and buy a non tilt, non cruise column if I could swap the parts over to make it a cruise and tilt wheel? These damn tilt & cruise wheels go for like 400$...
tecster is offline
post #2 of 5 (permalink) Old 04-06-2011, 04:56 PM
95powersmoker's Avatar
Re: steering columns
Only thing I can think of is you will need to cut a hole in it for the tilt knob. But other than that I'm not sure.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 5 (permalink) Old 04-06-2011, 05:44 PM
crazed & deranged farmer
NutFarmer97's Avatar
I'm of the personal opinion its better to rebuild what you got. I went through mine about 2 years ago and had to replace every bearing in it but its like a new truck once you do that.
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #4 of 5 (permalink) Old 04-06-2011, 06:01 PM Thread Starter
I don't think it's that easy, the 3 copper tabs that control the blinker cut off are broken, the plastic ring right behind the wheel itself is shattered...
tecster is offline
post #5 of 5 (permalink) Old 04-07-2011, 07:47 AM
Terminator Nation
The steering column is common to several other Ford vehicles, making it easier to find in the junkyards. Replacing the bearings does make it like new.
old man dave is offline
