Can someone explain this - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 04-06-2011, 04:57 AM Thread Starter
Nose picker
The body lines on my cab and bed seem off, well I think they are but only on the drivers side. The passanger side is fine. What would cause something like this to be happening? and whenever I hook up a trailer the bed dives more. The frame is straight and not tweaked. I bought the truck like this and thought it was the sagging cab mount bushings but after replacing them with OEM's this is still there.
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
post #2 of 24 (permalink) Old 04-06-2011, 06:34 AM
crazed & deranged farmer
NutFarmer97's Avatar
Re: Can someone explain this
Has the truck ever been in a wreck?
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #3 of 24 (permalink) Old 04-06-2011, 06:40 AM Thread Starter
Nose picker
I think it was hit in the driver rear but it was minor. It could've had the bedside replaced and just put on crooked but what gets me is when I hook up a bumper pull you can see the bed diving towards the rear.
Denver is offline
post #4 of 24 (permalink) Old 04-06-2011, 09:07 AM
Just another OBS addict
rancherstroker6's Avatar
How does the spacing between the cab/bed compare on either side. I think that'd help show a single-side issue. The only thing I could think of beside the frame and panel would be bent/worn out springs/shackle, but not sure how much that would affect the body lines. There's so much flex in OBS frames that I'm guessing it's possible you could have a slight bend but to the blind eye under the truck it looks fine.
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #5 of 24 (permalink) Old 04-06-2011, 11:44 AM
DieselAddict
j.soffa's Avatar
I think this is a factory thing. I had a 1995 F150, the bed was off. My 1997 F250HD, bed is off.... don't know why.
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
j.soffa is offline
post #6 of 24 (permalink) Old 04-06-2011, 12:01 PM
Demon Dually
speeddemon31176's Avatar
If the bed side was replaced and the alignment shims were not changed to counter any changes in the body lines then it will be off no matter what.
speeddemon31176 is offline
post #7 of 24 (permalink) Old 04-06-2011, 10:53 PM
04yfzkid's Avatar
Could it not be the cab / bed bushings? I have the same problem. I don't think my bedside was replaced because it sounds like it was bondo'd.
04 cobra - MMR 5.0 stroker, 3.4 whipple, e-85, 30psi of boost when the belt doesn't slip
Currently converting to 78mm turbo.
96 f-250, diamond eye catless / mufflerless, DIY 6637, white rodgers 586-902, marinco mod, Denso High torque gear reduction starter, led door and dome lights, and PHP hydra for now.
04yfzkid is offline
post #8 of 24 (permalink) Old 04-06-2011, 11:06 PM
STILL LEARNING
Bradbilt's Avatar
In that pic I dont see anything off but it is a ford thing, the frames are designed to flex as part of the suspension.
Holy crap Now yours is off especially for sitting on flat ground
But if you think that is bad, looky here
Bradbilt is offline
post #9 of 24 (permalink) Old 04-06-2011, 11:19 PM
04yfzkid's Avatar
Yeah that's what I am worried about. I want to try to fix it before I put fiberglass on it. I can always fix it by hanging the fiberglass different to compensate, but that's a president-rig fix in my opinion.
Sadly I know all too much about these type trucks frame flex. Sometimes it eve gets stuck that way
04yfzkid is offline
post #10 of 24 (permalink) Old 04-07-2011, 01:04 AM
Dreams of owning cclb
97obs's Avatar
FTW
97 F250HD 4x4-3:55s
,ts 6 pos chip(tuned by [email protected]), 3'' downpipe to custom 5" straight exhaust, diy 6637 intake, Beans Stage 1s, CCV mod, Beans Non-EBPV pedestal, Stancor Relay, 6.0 IC, 16x10 American Racing Outlaw IIs, 4" Rough Country lift, 285/75/16s
97obs is offline
