New manual fuel pump wont work - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-06-2011, 04:21 AM Thread Starter
smokinstroke97's Avatar
I can't get the new manual fuel pump to fill the fuel bowl. I put in a new long block and put a new pump on, should all camshafts have the lobe to make the pump work. Is there a way to prime or check pressure at the pump?
97 F-250 Extended Cab 4x4 Powerstroke, Handshaker, FPR Shim mod, straight pipe.
06 Dodge Dually Quad Cab 4x4 Cummins, Goerend 48re, J and I flatbed, BD Triple Dog, Autometer Trans, Boost, Pyro,
smokinstroke97 is offline
post #2 of 12 (permalink) Old 04-06-2011, 04:37 AM
<<< Power
chvyrkr81's Avatar
Re: New manual fuel pump wont work
What year is the long block?
Not all cam's have the fuel pump lobe.
06
02
97
74
chvyrkr81 is offline
post #3 of 12 (permalink) Old 04-06-2011, 01:03 PM Thread Starter
I'm not sure how do you tell
post #4 of 12 (permalink) Old 04-07-2011, 02:18 AM
you did put the rod in the bottom of new fuel pump? You could unbolt the fuel pump and turn it the motor over buy hand and see if the pump raises up.
94 psd is offline
post #5 of 12 (permalink) Old 04-07-2011, 02:23 AM
Dairy Mechanic
Magnum PD's Avatar
Do what he said, and look at the cam to see if there is any lope.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #6 of 12 (permalink) Old 04-07-2011, 03:24 AM Thread Starter
The old pump and new pump looked the same, was there a rod that I was supposed to switch.
post #7 of 12 (permalink) Old 04-07-2011, 04:07 AM
Nose picker
Did you fill the fuel bowl prior to first start up?
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
post #8 of 12 (permalink) Old 04-07-2011, 07:31 AM
Terminator Nation
There is a pushrod that transfers to the replacement pump.
old man dave is offline
post #9 of 12 (permalink) Old 04-08-2011, 03:19 AM Thread Starter
Does anyone have a pic of that pushrod. Not sure how to copy and paste on iPod. Waiting at hospital for birth of second son. I think my new pump might have come with one. Thanks
post #10 of 12 (permalink) Old 04-08-2011, 03:21 AM Thread Starter
No didn't put fuel in bowl but it wasn't filling either
