Oil leaking down to inspection plate - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-06-2011, 04:12 AM Thread Starter
smokinstroke97's Avatar
I found one oil line that I didn't get tightened, and the oil ran down to the drain hole in the valley. It is coming out of the inspection plate. I am going to take it off tomorrow to see if there is anymore oil in there. Could there be a plug or something I missed on the back of the engine if no more oil is coming out of the valley drain hole?
97 F-250 Extended Cab 4x4 Powerstroke, Handshaker, FPR Shim mod, straight pipe.
06 Dodge Dually Quad Cab 4x4 Cummins, Goerend 48re, J and I flatbed, BD Triple Dog, Autometer Trans, Boost, Pyro,
smokinstroke97 is offline
post #2 of 10 (permalink) Old 04-06-2011, 12:07 PM
Demon Dually
speeddemon31176's Avatar
Re: Oil leaking down to inspection plate
Once you stop the leak the oil will stop coming out of the valley once it dries up. There are no plugs to remove.
speeddemon31176 is offline
post #3 of 10 (permalink) Old 04-06-2011, 01:02 PM Thread Starter
I didn't know if there might be a plug or something on the back side of the motor I might have not tightened or if all that oil was just from that one fitting. Thanks will look at it again today
post #4 of 10 (permalink) Old 04-06-2011, 03:51 PM
This might seem crazy but we had the same track of a leak down the inspection plate. It acctually was traveling up from a flattened brass washer on oil pan. Ed E
erskine_e is offline
post #5 of 10 (permalink) Old 04-06-2011, 04:32 PM
The turbo could be leaking from the pedestal orings. Or it could be from the 2 large plugs on the rear of each head. They are around the size of a silver dollar.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
BlindViper is offline
post #6 of 10 (permalink) Old 04-06-2011, 04:32 PM Thread Starter
Usually my problems start out with, "We have never seen that before." so I will look at that too. Thanks
post #7 of 10 (permalink) Old 04-06-2011, 04:55 PM
95powersmoker's Avatar
Like Speeddemon said, Find the leak in the valley and fix it...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #8 of 10 (permalink) Old 04-07-2011, 03:25 AM Thread Starter
Ok thanks
post #9 of 10 (permalink) Old 04-07-2011, 06:26 PM
Exclamation Re: Oil leaking down to inspection plate
Also you have to be sure if its oil, or its fuel combined with junk of the motor seeming to be oil.
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #10 of 10 (permalink) Old 04-15-2011, 02:28 AM Thread Starter
Almost positive it is not leaking from the valley. There is only one weep hole from the valley, correct? It runs down under the crank, but only runs after you stop cranking the motor. If it were a rear main seal installed wrong wouldn't it leak all the time. This acts as if the cranking of the motor build pressure and when cranking stops the pressure of oil is released? I am stumped thinking of pulling the tranny again, but not sure I will be able to see any more do to the flywheel.
