Converting to SD GP/Inj UNVC harness - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-05-2011, 12:01 AM Thread Starter
gnxtc2's Avatar
So whats involved converting to a Super Duty injector/glow harness? I heard that the SD wiring is heavier gauge wire.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #2 of 2 (permalink) Old 04-05-2011, 01:15 AM
hit n miss
Peroni's Avatar
Re: Converting to SD GP/Inj UNVC harness
You will need SD UVCH, VC gaskets and the connector plug w/ pins plus solder,heat shrink tube and RFI shielding tape. Also have on hand some wire loom and electrical tape, mine was all brittle from heat and needed replacing.
Inside the main wire bundle the common ground wires for each bank split off, you need to cut one branch off for each bank so you are left with one wire per side. The high voltage injector wires get hooked up in same order as they were with the OBS connectors. I have the wire colors written down somewhere of what goes where, I'll post em up tomorrow.
It's really very easy, just a matter of carefully cutting/splicing the right wires in the right places.
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
