Window problems... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-04-2011, 04:53 AM Thread Starter
PowerStroke Fan
patrick66's Avatar
Window problems...
Up til around January or so, all four power windows worked fine in my '95 Crew Cab. Now, I've got some problems...
1) The DS front window goes down fine, but UP is another thing. If I make the mistake of rolling it down all the way, it's a bee-atch to grab the glass and help it back up with the motor and my hand. You can hear the motor go, and sometimes it'll grab the window and roll it up.
2) The DS rear window is similar...goes down fine, but will not go back up without manually assisting it, Same problem, whether with the master or the rear door switch.
3) The PS front is good, knock on wood...
4) The PS rear is finicky. It'll go up and down fine most times, but I have difficulty occasionally with the UP with the master and door switches both on that window.
I've checked the archives and can't find what I'm looking for, far as an answer goes. Any ideas?
1995 F350 SRW XLT 4x4 LB CC
patrick66 is offline
post #2 of 12 (permalink) Old 04-04-2011, 05:08 AM
Team Shade-Tree Mechanic
Mini-Stroke...'s Avatar
Send a message via AIM to Mini-Stroke...
Re: Window problems...
Have you pulled the door panels and looked to see if the track is messed up or if the regulator is on its way out?
96 PSD 4X4, 33's, intake, 4" straight exhaust, Autometer NV gauges, Edge
, ZF5 tranny, LUK clutch. D60 swap in the works......
87 Diesel ranger 4X4
Mini-Stroke... is offline
post #3 of 12 (permalink) Old 04-04-2011, 06:00 AM
Location: Idaho... potatoes aint the only thing that we grow
If you can hear the motor spinning but nothing happens, the plastic pieces inside are broken. I have taken them apart and fixed them, but should just replace the whole motor.
dave186 is offline
post #4 of 12 (permalink) Old 04-04-2011, 04:00 PM
zilla68's Avatar
mine did the same thing, tracks were completely dry, greased them up with lithium type grease and they work great ever since.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #5 of 12 (permalink) Old 04-04-2011, 04:21 PM
Mine was the regulator check that also
rake18 is offline
post #6 of 12 (permalink) Old 04-04-2011, 09:36 PM
Patrick Feeley's Avatar
The passenger side rear on my 94 did the same thing. It turned out to be the plastic "dogs" in the motor drive that disintegrated. You can get new ones in the HELP! section at your local auto parts place (part number 74410). Some folks have also used 5/16" nuts to replace those parts. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #7 of 12 (permalink) Old 04-04-2011, 11:07 PM
STILL LEARNING
Bradbilt's Avatar
I got to look into my 97 crew. The passenger rear window does nothing. I hope its not a broken wire
Bradbilt is offline
post #8 of 12 (permalink) Old 04-04-2011, 11:10 PM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
we had the same issue on our thunderbird, i dont know if its the same setup but on the motor there is a plastic gear inside another metal gear so if it binds up the plastic gear strips instead of damaging the motor, ive never had the window assy apart so i dont know if its the same on the trucks
Refugee
pstroke96 is offline
post #9 of 12 (permalink) Old 04-04-2011, 11:21 PM Thread Starter
PowerStroke Fan
patrick66's Avatar
Outstanding, thanks for the hints. Now, I've got something to do this weekend with a reasonable idea of a fix...or fixes.
post #10 of 12 (permalink) Old 04-05-2011, 11:20 PM
04yfzkid's Avatar
Thanks for the part number!
I will have to try that! My truck was texas truck so I am sure they are probably dry by now. The back ones go up really really slow.
On my driver side rear, I had the wire break between the b-piller and the door. It was really obvious when I was detailing it one day. I was pissed because I drove it for several months like that, and cruising the beach in cali with 3 windows down was weird
04 cobra - MMR 5.0 stroker, 3.4 whipple, e-85, 30psi of boost when the belt doesn't slip
Currently converting to 78mm turbo.
96 f-250, diamond eye catless / mufflerless, DIY 6637, white rodgers 586-902, marinco mod, Denso High torque gear reduction starter, led door and dome lights, and PHP hydra for now.
04yfzkid is offline
