more problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-04-2011, 03:46 AM Thread Starter
It likes 4400 rpm!
more problems
Still never got my miss completely figured out, but now im having a new problem,
I will be driving along and all of a suddon my truck looses power and it wont pull little hills without shifting into 3rd and flooring it and even then it struggles the engine sounds like its running fine not even missing, it just looses all power and throws a CEL, i will try to borrow the scanner tomarrow
1986-FORD F-250, 4X4, T-19,6.9 bored.020 MANY MODS, and broke again
1995-F-350, ext cab, DRW, 2WD, 291,xxx miles , ZF5, MODS:chopped exhuast, FPR shimmed, 6637, gutted ebpv
dyoung14 is offline
post #2 of 12 (permalink) Old 04-04-2011, 03:49 AM
Dairy Mechanic
Magnum PD's Avatar
Re: more problems
Scanner will be the answer. May need to check your oil level.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #3 of 12 (permalink) Old 04-04-2011, 06:43 AM
Nose picker
Re: more problems
It's probably an IPR issue. Mine did the same thing. Going up hill and then went down to about 20% power CEL came on and then power came back up. It was an IPR code. Just serviced it today and installed new o rings and runs a hell of a lot better.
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
post #4 of 12 (permalink) Old 04-07-2011, 02:42 AM Thread Starter
It likes 4400 rpm!
Re: more problems
Ok i put the scanner on and it said something about injection pressure way too high or something i forgot to right it down
dyoung14 is offline
post #5 of 12 (permalink) Old 04-07-2011, 11:11 PM
Re: more problems
You still have an injector issue!!! Fix that and I bet all other problems go away!!! Make sure your lift pump is ok.
1994 F-350 4x4 RC 7.3 IDI Turbo, BTS E-4OD, ATS upgrades, BB injectors, Moose Pump, Holley Red.
1997 F-350 CC 4x4 7.3, E-4OD, 6" lift, 38" swampers, 160/80% RDS injectors, TDP tunes.
2001 F-250 RC 4x4 7.3, 4R-100, Straight piped, PHP tune, Western 8.5 MVP.
2003 E-350 7.3, 4R100, 3.55LS. Stock(For now)
t444epsd is offline
post #6 of 12 (permalink) Old 04-08-2011, 01:30 AM Thread Starter
It likes 4400 rpm!
Re: more problems
I think it is leaking as well i hate this truck, but its reliable
dyoung14 is offline
post #7 of 12 (permalink) Old 04-08-2011, 01:32 AM
STILL LEARNING
Bradbilt's Avatar
Re: more problems
Better get building your twin turbo IDI
Bradbilt is offline
post #8 of 12 (permalink) Old 04-08-2011, 01:44 AM
Re: more problems
t444epsd is offline
post #9 of 12 (permalink) Old 04-08-2011, 04:01 AM Thread Starter
It likes 4400 rpm!
Re: more problems
Im working on it right now! laugh all you want! i aint spending the money on this powerstroke, no use in it, i will drive it till it gives up and then scrap it and put that money in my 86, its a nice truck but i just hate powerstrokes with a passion
dyoung14 is offline
post #10 of 12 (permalink) Old 04-08-2011, 04:08 AM
I helped make ur rimz....
MadMax'97PSD's Avatar
Re: more problems
then why did you buy a powerstroke?
'95 F-350 Crew Cab Dually 7.3L. 187k miles - 6637, bitchin aftermarket headlights
'97 F-250 extended cab 7.3L 216k miles-6637, 4in straightpipe
'99 Dodge 2500 Laramie SLT 5.9L 222k miles- flex pipe exhaust, fatal 53 block- fml.
'92 F-350 CCLB 4x4 7.3IDI
Diesel- Fuel 4 Life
MadMax'97PSD is offline
