another oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-04-2011, 03:40 AM Thread Starter
14psd's Avatar
another oil leak
Ok here is what I have done so far. The IPR appeared to be leaking so I replace the o-rings and cleaned it. I also found that my HPX hose had a pin hole in it spraying oil everywhere, replaced that. I have had oil in the valley during the replacement of both of the above mentioned. I cleaned the oil out. I have even leaned over the engine and had my daughter rev the truck up to 2k to look for leaks. I can't find any. I have used a mirror on a stick to look under stuff (that's how I found the HPX hose leaking) and cannot find this leak. I do know that is definitely oil. Its black and nasty. I have done the fuel pump enough times to know its not that THIS time. I did replace the o-rings on the fittings that attach to the head for the HPX hose. I think I covered everything I have done. One last thing, I have been all over this site trying to find info on this. I have found info on everything I have done. Please give me some ideas where else to look.
Todd
__________________________________________________ _________________________________
'95 F-350 daully, Super Cab, 230K+ miles, 2 wd, automatic, Bean's stage 1, shimmed fpr, 3" down pipe, superchip, gauges boost, EGTs, trans, and volts, missing Kitty & muffler, Homemade tymar set-up, HPX mod, CCV mod, and air bags in the rear
14psd is offline
post #2 of 5 (permalink) Old 04-04-2011, 04:14 AM
mleg1972's Avatar
Re: another oil leak
What about the turbo pedestal orings? Mine were parking and I had oil all in the valley.
2000 F350 4x4 SRW ZF6, Superchips flashpaq, 4in down pipe with 5in Turbo back no muffler exhaust, future mods on the way.
mleg1972 is offline
post #3 of 5 (permalink) Old 04-04-2011, 02:20 PM
OBS Addict
7.3psd97444's Avatar
Check the oil rail plug. Behind the alternator and it's bracketing. Big ol plug that likes to leak on these trucks.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 5 (permalink) Old 04-04-2011, 02:30 PM
Fixing Broken Stuff
toolmangary's Avatar
^^^^ What they said
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 5 (permalink) Old 04-04-2011, 08:31 PM Thread Starter
14psd's Avatar
Is it possible for the oil to be coming out of the big circle of the hpop on the back? I hope I'm making since? Not the plug next to the IPR nor the IPR but to the left on the picture here. That's where I found the oil to be coming from finally. I drove the truck after cleaning the valley again. With towels down in the valley. I found out the oil is coming from up front and from the HPOP. At idle it has a slow drip and at higher speeds/loads I'm sure it squirts out of there. Now the fix? I will replace that plug's oring also but the oil was coming down the passenger side of the back of the HPOP.
Todd
14psd is offline
