Engine swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 04-03-2011, 09:01 PM Thread Starter
jim
Engine swap
Is there any mods that would be necessary to switch from a 97 pstroke to a 95? Looking into salvaging a wrecked truck
jmiller9339 is offline
post #2 of 19 (permalink) Old 04-03-2011, 09:05 PM
Re: Engine swap
Im pretty sure it will swap right over.
02 f250
countryboyrob is offline
post #3 of 19 (permalink) Old 04-03-2011, 09:08 PM
OBS junkie
Cat_Rebel's Avatar
Re: Engine swap
I don't exactly get what your trying to do Jim. Do you have a 95 & want 97 parts or a 97 & want 95 parts?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 19 (permalink) Old 04-03-2011, 10:00 PM Thread Starter
jim
Re: Engine swap
I have a 97 and want to swap the 95 motor in
post #5 of 19 (permalink) Old 04-03-2011, 10:09 PM
Re: Engine swap
Is there anything wrong with the 97?
02 f250
post #6 of 19 (permalink) Old 04-03-2011, 10:27 PM Thread Starter
jim
Re: Engine swap
No but my brothers gettin the salvaged 95 and rebuilding the motor and taking all the parts(bed , interior, doors) and putting them into the 97. The 95 has a bent frame but the engine and built tranny are good .
post #7 of 19 (permalink) Old 04-03-2011, 10:36 PM Thread Starter
jim
Re: Engine swap
The 97 bed just a little beat up and the interior is too
post #8 of 19 (permalink) Old 04-03-2011, 10:41 PM
Re: Engine swap
So basically you wanna put a rebuilt 95 into your truck which has a motor with over 200k miles on it?
02 f250
post #9 of 19 (permalink) Old 04-04-2011, 12:21 AM
OBS junkie
Cat_Rebel's Avatar
Re: Engine swap
Your better off with the 97 engine unless it's hurt. The 94-95s have a few different parts that can all be changed but the block is still weaker. Not an issue if you aren't building the power up.
Here is a brief run down on what's different....
-Intake plenums
-Front cover
-Hpop
-IPR
-Turbo pedistal
-Up pipes
-Oil pickup tube
-Oil pan
-EOT sensor
-Block casting
Prob something else I'm forgetting. Nothing wrong with the 94-95s but they are a little different.
RIP Will Iott
post #10 of 19 (permalink) Old 04-04-2011, 12:24 AM
Demon Dually
speeddemon31176's Avatar
Re: Engine swap
Lets not forget the bleed back issues the early motors have and the oil bypass that likes to fall apart.
speeddemon31176 is offline
