Where is my problem located? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-01-2011, 02:39 AM Thread Starter
Built not Bought
1990 Scorpion's Avatar
So this has happened two times now, I go to start my truck and the ignition just clicks over. My entire ignition assembly is new, so is it my starter relay or starter. Or none of the above and it lies in the wiring?
When this happens I have to use a screwdriver and cross the terminals on the starter relay to crank the truck over.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #2 of 14 (permalink) Old 04-01-2011, 04:17 AM
95powersmoker's Avatar
Re: Where is my problem located?
If the truck cranks when you jump the starter relay, the relay is bad...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 14 (permalink) Old 04-01-2011, 04:42 AM Thread Starter
Built not Bought
Thank you for the input I'll go grab a new relay tomorrow. Now I just have to find the draw that's draining my batteries.
S&B Intake
post #4 of 14 (permalink) Old 04-01-2011, 05:29 PM
blageurt's Avatar
Defective Starter relay can also drain the batteries ....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #5 of 14 (permalink) Old 04-01-2011, 09:03 PM Thread Starter
Built not Bought
That is good to know, also the two problems are twins as in when the starter relay first started going bad my batteries started to drain. After I get the new relay in today I'll post up my results.
S&B Intake
post #6 of 14 (permalink) Old 04-01-2011, 09:21 PM
PSN Pontiac Enthusiast
b00stleak's Avatar
Loose battery cables? If the connection is bad enough it will just click like a dead battery when you turn the key.
b00stleak is offline
post #7 of 14 (permalink) Old 04-02-2011, 12:14 AM Thread Starter
Built not Bought
I checked my battery cables and snugged them all up just incase. I had previously had a no start from loose battery cables and gave my friend I nice jolt when he wiggled the connection and the key was still on lol.
S&B Intake
post #8 of 14 (permalink) Old 04-02-2011, 08:02 AM Thread Starter
Built not Bought
I changed out my relay tonight, now only time will tell if I eliminated my no start problem and the draw on my batteries. I'll post up what my results are.
S&B Intake
post #9 of 14 (permalink) Old 04-02-2011, 08:19 AM
Demon Dually
speeddemon31176's Avatar
Disconnect your negative cable on the pass side battery and hook a multimeter to it with it on the dc amp setting. Put one lead on the negative terminal on the battery and one lead on the negative terminal on the cable and see if you have a substantial amp draw. If you can get your hands on an amp clamp that does dc that would be even easier. Hook it around the positive cable on the pass battery or on the cable from the alternator and see if you are drawing more than a few milliamps.
speeddemon31176 is offline
post #10 of 14 (permalink) Old 04-02-2011, 09:04 AM Thread Starter
Built not Bought
I will be doing that for sure, I've been reading up on it lately to make sure I can do it correctly. On Monday a friend of mine will be loaning me his multimeter so I can really find my draw. Thank you for the input, your advice pushed me to do it instead of just live with it.
S&B Intake
