Tricks to putting standard trans back in - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-31-2011, 11:38 PM Thread Starter
smokinstroke97's Avatar
Just pulled my standard transmission. Is there any tricks to gaining any clearance when putting it back in? Is it easier to split tranny and transfer case?
97 F-250 Extended Cab 4x4 Powerstroke, Handshaker, FPR Shim mod, straight pipe.
06 Dodge Dually Quad Cab 4x4 Cummins, Goerend 48re, J and I flatbed, BD Triple Dog, Autometer Trans, Boost, Pyro,
smokinstroke97 is offline
post #2 of 6 (permalink) Old 04-01-2011, 04:36 AM
Patrick Feeley's Avatar
Re: Tricks to putting standard trans back in
My two tips:
Tranny jack and remove the shifter stub. Cheers!
Patrick Feeley is offline
post #3 of 6 (permalink) Old 04-01-2011, 06:38 AM
Demon Dually
speeddemon31176's Avatar
Always separate the trans from the transfer case. The transfer case adds a lot of off balance weight which can make it near impossible to line up the input ans the bell housing at the same time due to the transfer case trying to twist the transmission off the jack to one side.
speeddemon31176 is offline
post #4 of 6 (permalink) Old 04-01-2011, 01:28 PM Thread Starter
sounds good thank ya'll
post #5 of 6 (permalink) Old 04-01-2011, 11:56 PM
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
pull tcase. Use alinement tool to set clutch into center. then push it in strieght
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
post #6 of 6 (permalink) Old 04-02-2011, 12:07 AM
Death Row Inmate #7
strokin'_tatsch's Avatar
No real tricks.. I usually just put the transmission in gear(any gear) and if the input splines aren't lining up just right, reach back and spin the output shaft a bit so the input splines will line up. Pulling the shifter stub will help with clearance, but I've never had a problem with it being in the way too much.
I would pull the transfer case also. That's easy to put in once the transmission is in and only makes it more of a PITA to get the trans lined up right.
Travis
1995 F-250 SC 2wd zf-5
strokin'_tatsch is offline
