Rough Running, Tons of Smoke?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-31-2011, 01:23 AM Thread Starter
Hi guys, been lurking here for a few months. Been having problems with my 97 f250. Truck started missing really badly every now and again when cold, CEL would come on, and then just snap out of it and run fine for days. Then it would happen again, sounds like it would be running on 5-6 cyls. Eventually started doing it more and more until it would not clear up at all. Changed UVCW since old was burnt up pretty bad, didnt help. Swapped IDM for a modded swamps unit. Threw more codes than old IDM.
Old IDM-
p0270 inj crkt low 4
p1272 inj high/low side open 2
p1274 ^^ 4
New IDM-
p0270
p1271, 73, 74, 76, 77, 78
p1293, 94 high side open bank 1 and 2
p1298 IDM failure
Passes buzz test and all that good stuff but wont clear up and run. Installed baby swamp injectors and fired up to get air out, smokes a little white for 20 seconds or so then kicks down into missing badly again but now is smoking a ton of black smoke. Any ideas where to start?? Thanks!
1985mustanggt50 is offline
post #2 of 5 (permalink) Old 03-31-2011, 01:31 AM
Re: Rough Running, Tons of Smoke??
ipr would be my guess
Matt07 is offline
post #3 of 5 (permalink) Old 03-31-2011, 03:44 AM
blageurt's Avatar
All UVC harnesses /Gaskets/ Connectors /wiring good and solid ?
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #4 of 5 (permalink) Old 03-31-2011, 04:44 PM
04yfzkid's Avatar
I had pretty much the same problem as listed above. It turned out my brand new dorman VC and UVCH was wired wrong. One plug had the glow plug wire and injector wires backwards. Rewired it on the outside with the new pigtails and have no problems since.
04 cobra - MMR 5.0 stroker, 3.4 whipple, e-85, 30psi of boost when the belt doesn't slip
Currently converting to 78mm turbo.
96 f-250, diamond eye catless / mufflerless, DIY 6637, white rodgers 586-902, marinco mod, Denso High torque gear reduction starter, led door and dome lights, and PHP hydra for now.
04yfzkid is offline
post #5 of 5 (permalink) Old 03-31-2011, 08:06 PM
Fixing Broken Stuff
toolmangary's Avatar
It sounds like your UVCH's , you better take a closer look
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
