Eng. Temp. light came on but... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-30-2011, 07:32 AM Thread Starter
Ok, so what is causing the "Eng Temp" idiot light to light up all of a sudden? The temp. gauge on the left side of the dash is still pointing between the "O" and the "R" in NORMAL. Didnt smell hot. and didn't feel hot! 4 hours later, it damm sure wasn't hot, so why is the "Eng Temp" light still glowing?
And on a nother note, the damm dome lights won't go out. I had to pull the bulbs. I checked the door triggers and they seemed ok but what do I know
jacmurr is offline
post #2 of 12 (permalink) Old 03-30-2011, 08:01 AM
Demon Dually
speeddemon31176's Avatar
Re: Eng. Temp. light came on but...
Engine temp light staying on regardless of temp would indicate to me that either the sending unit or the wiring to it are faulty. You could also have a faulty pcm. Your dome lights staying on can only be one of three things. Either the switch is turned to the dome light on position/faulty light switch, one of the door pin triggers are faulty, or you have the ground wire to one of the door pin switches grounding out keeping the lights on. If it is a crew cab truck, look at the wiring running from the drivers kick panel to the B post as this is a common location for the wiring to corrode and cause all sorts of problems.
speeddemon31176 is offline
post #3 of 12 (permalink) Old 03-30-2011, 02:59 PM Thread Starter
Can you tell me where is the eng temp sensor? and B post? TIA
jacmurr is offline
post #4 of 12 (permalink) Old 03-30-2011, 06:13 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
there are two sensors, one on top the water pump, which i believe is for the guage. the other is on the pass side part way down the motor.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #5 of 12 (permalink) Old 04-01-2011, 06:07 AM
Demon Dually
The idiot light sender is on the pass side of the engine as stated above. The B post is the post that is in between the front and rear doors of a crew cab, or the rear post of a regular cab, or the post that the striker for the door latch is mounted to on a super cab.
post #6 of 12 (permalink) Old 04-02-2011, 04:32 AM
Are you sure the dome light is turned off at the headlight switch? (Sorry; gotta eliminate the obvious...)
madpogue is offline
post #7 of 12 (permalink) Old 04-03-2011, 04:27 PM Thread Starter
Thanks guys, but I'm still having difficulty finding the engine temp. sensor. Is there some kinda sensor location diagram so I know exactly where to look?
jacmurr is offline
post #8 of 12 (permalink) Old 04-03-2011, 06:40 PM
Crazy Talk
i think, its been awhile since mine had one, but it should be in the block between the pass side acces bracket and the timing cover, just below the head.
post #9 of 12 (permalink) Old 04-03-2011, 06:46 PM
Crazy Talk
here you go where the red circle is.
post #10 of 12 (permalink) Old 04-03-2011, 06:52 PM Thread Starter
Ok, like behind the idler pully?
jacmurr is offline
