obs seat swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-30-2011, 12:38 AM Thread Starter
obs seat swap
hey just had a few questions trying to swap in some 1997- 2003 f150 lariat seats into my OBS F350 just wondering if anyone has done this and has any pointers I'm going with the f150's cause I assumed the super duty's were too wide
Thanks
loughnan is offline
post #2 of 4 (permalink) Old 03-30-2011, 12:55 AM
Re: obs seat swap
I have a set from an 02 F150 extended cab that i thought I could make work in my 93, once I sat them in the cab it was clear that it would take major surgery to get them to sit low enough to work. They are now sitting and waiting for the right project to come along.
06 F350 4x4 ext cab dually, 6.0, auto, stock
95 F350 4x4 reg cab, powerstroke, 5 speed, banks brake, buckstop bumper, superchips
97 F350 4x4 crew cab, powerstroke, 5 speed, stock
93 Dodge Cummins, stock
11 GMC Duramax, stock
94Matt is offline
post #3 of 4 (permalink) Old 03-30-2011, 06:00 AM
Demon Dually
speeddemon31176's Avatar
Re: obs seat swap
If you pull out the seat tray you can modify them to work but it will require drilling new mounting holes in the floor.
speeddemon31176 is offline
post #4 of 4 (permalink) Old 03-31-2011, 12:55 AM
pmasterson's Avatar
Re: obs seat swap
I bought 2000 SD Lariat seats for my F350 CC and yanked the old seats and carpet out and had just put the seats in to see what needed to be drilled, shimmed, fitted, etc. My sister called and needed to borrow my car so I only had a few hours to get my truck back together in order to have transportation. So I went the quickest route which was to take the mounts off the SD seats and fit them to the OBS 40/20/40 mount bracket. I drilled and mounted them to the seat tracks on the OBS bracket and put 'em in. Fit great. Rear seats just needed new mounting holes in the floor and also fit great.
1995 F350 CCLB 4X4
TW tunes, GS gauges, Aeroforce Interceptor
3" RSK w/SD springs & Bilsteins
DIY 6637, 3" DP to straight exhaust
pmasterson is offline
