Maintenance questions. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-29-2011, 04:31 PM Thread Starter
psdguy97
psdguy08's Avatar
I'm going to switch my sig truck over to amsoil this week. I'm still new to these trucks so I have a couple questions. How much fluid to each of these take...
Rear axle
Front axle (Dana 50)
t-case
Trans
Also what kind of power steering fluid do these trucks take?
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
post #2 of 10 (permalink) Old 03-29-2011, 05:22 PM Thread Starter
psdguy97
psdguy08's Avatar
Re: Maintenance questions.
I know the trans is about 7 or 8 quarts.
95 F-250 ECLB
psdguy08 is offline
post #3 of 10 (permalink) Old 03-29-2011, 07:01 PM
zilla68's Avatar
its on the amsoil site somewhere, it lists all the fluid amounts.
this is for a 96 f350 diesel and came off their site:
CAPACITIES:
Engine, with filter..........14 quarts [1]
Cooling System, Initial Fill..........22.8 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, E4OD Initial Fill..........6.5 quarts
Automatic Transmission, C6-Deep Pan Initial Fill..........6 quarts
Automatic Transmission, C6-Shallow Pan Initial Fill..........5 quarts
Automatic Transmission, Total Fill
4 speed E4OD..........Not Specified
3 speed C6-Deep..........13.6 quarts
3 speed C6-Shallow..........Not Specified
Manual Transmission, 5-SPD Mazda..........7.7 pints
Manual Transmission, 5-SPD ZF..........6.8 pints
Manual Transmission, S5-42..........6.8 pints
Manual Transmission, S5-47..........6.8 pints
Differential, Dana 44 Front..........3.6 pints [2]
Differential, Dana 50 Front..........3.9 pints [2]
Differential, Dana 60 Front..........6 pints [2]
Differential, Dana 60-IU Rear..........6.4 pints [2]
Differential, Dana 70 EX HD Rear..........6.6 pints [2]
Differential, Dana 70 HD Rear..........7.4 pints [2]
Differential, Dana 80 Rear..........8.5 pints
Differential, Ford 10.25 RingGear Rear..........7.4 pints [2]
Differential, With 8.8 or 9 RingGear Rear..........5.5 pints [2]
Transfer Case, W/ PTO..........12.3 pints
Transfer Case, Warner 1356..........4.1 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Fill to no more than 1/4 to 9/16 inch below fill plug hole.
TORQUES:
Oil Drain Plug.....NA ft/lbs
Manual Transmission
Fill Plug 25-30 ft/lbs
Drain Plug 25-30 ft/lbs
Transfer Case
Fill Plug 12 ft/lbs
Drain Plug 12 ft/lbs
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #4 of 10 (permalink) Old 03-29-2011, 07:40 PM
TBarrsTruck's Avatar
if your have a converter drain, I do on my 97, then it will hold a lot more tranny fluid after you drain it, can't remember but think it was in the 17-18 qrt range after pan drop and converter drain. P/S just use atf.
Also might mention that if you can find Schaeffers fluids you might think about them instead of amsoil.
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #5 of 10 (permalink) Old 03-30-2011, 03:47 AM Thread Starter
psdguy97
psdguy08's Avatar
Thanks guys. Why schaeffers over amsoil?
95 F-250 ECLB
psdguy08 is offline
post #6 of 10 (permalink) Old 03-31-2011, 03:25 AM
Cost mostly, but they offer great products for less money cause they don't sponsor things (like nascars) and aren't available at parts houses. If you do some research on here for their name you'll find lots of good stuff. Their fuel treatments too. I've been using their products now for a couple years and I go 10k on oil changes now and they sample my oil for free everytime to make sure everything is A OK. I was using Rotella with the Lucus additive and my truck would get hard to start after about 4K so I would just change the oil. Never have any starting issues with Schaeffers, even at 10K.
post #7 of 10 (permalink) Old 03-31-2011, 05:07 AM Thread Starter
psdguy97
psdguy08's Avatar
Hmm. i'm going to look into this.
95 F-250 ECLB
psdguy08 is offline
post #8 of 10 (permalink) Old 03-31-2011, 03:48 PM
It's worth the money for Schaeffers IMO, or you could go with Valvoline 5W40 syn (extreme blue) a lot of guys on here like it and it's easier to find.
post #9 of 10 (permalink) Old 03-31-2011, 06:46 PM
Its much better changing out the engine oil at 3-4k than longer Syn's or not..
email:
Website:
OBSWIZ is offline
post #10 of 10 (permalink) Old 03-31-2011, 11:40 PM
Normally I would agree, but I only go that far because I get my oil sampled and know that it isn't shearing or contaminated or losing it's important additives, so if it's like brand new then why would I dump it for new?
