Fuel Selector Switch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-29-2011, 04:44 AM Thread Starter
Hi All,
Used the Search Function, but may be typing in the wrong keywords...tried "fuel selector," "selector valve," "fuel tank switch" etc. to no avail.
That being said, my 1995 OBS fuel switch recently is acting a bit strange and I wanted to troubleshoot it here. The rear tank seems to read fine, but it seems as though when I switch to the front tank, its always reading 3/4 to totally full, even as I know I'm running the truck hard. I drove the truck hard solid for a week putting over 100 miles on the truck and the lowest the gauge read on the front tank was 3/4 full. When I switched to rear tank and drove hard for 20 miles, constantly fueling the truck to test this tank, I saw the fuel going down normally. Looks as though the front tank/sender/valve is acting up. Any suggestions/ideas?
Can anybody point me in the right direction?
Thanks
1995 Ford F-350 SC/LB PSD - 200k on the ticker - Tymar Intake, TP 6 Position - Bean's Tunes, 4" Diamond Eye Turbo Back, Alcoas with General Grabber AT2s
550ss is offline
post #2 of 2 (permalink) Old 03-29-2011, 05:49 AM
Demon Dually
speeddemon31176's Avatar
Re: Fuel Selector Switch
Pull the front tank and fix or replace the sender.
speeddemon31176 is offline
