Slight miss/rough idle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-29-2011, 02:52 AM Thread Starter
97 f350 banks inter cooler/turbo/exhaust/tymar --NEW cps
so my truck when it starts up cold it runs great, heck it runs pretty damn good all the time, but after its been running for a few minutes say 5 or more it starts to get a slight miss/rough idle that shakes the truck etc slightly and doesn't sound right.
New UVCH glow plugs etc.
it is small but noticeable, and cant be right. Im trying to eliminate things in the injection system etc.
What could be causing this? could a bad ICP sensor(oil thingy in HPOP) be causing this?
Im at a loss, as it gets worse when it heats up then stays the same...weird stuff....its like the oil or fuel or something heats up and thins out and causes this or?
Thanks in advance
res0wc18 is offline
post #2 of 12 (permalink) Old 04-08-2011, 11:20 PM
cadd's Avatar
Re: Slight miss/rough idle
I have the same issue, but I'm guessing it's my old injectors.
Travis
1999.5 F350 CC 4x4
& 2002 F250 CC 4x2 (Wifes)
cadd is offline
post #3 of 12 (permalink) Old 04-09-2011, 08:10 PM
sambosque90's Avatar
i have the same issue i got new injectors, new hpop no change at all. then i got a new idm seemed to help run smoother but its still misses when under boost.
96 eclb 12 inch lift on 40" swampers (sold)
97 reg cab 4" lift 20x12 fuel hostage deep
35x13.50 MT atz 6637
3"mbrp dp straight piped 6"stage 1 rosewood injectors
17* te hpop php tunes
custom fass efuel by fcdp
(sold)
95 eclb 64k miles super clean and stock for sale
96 rclb 71k miles garage queen
sambosque90 is offline
post #4 of 12 (permalink) Old 04-14-2011, 05:53 AM
97Stroker
97f2507's Avatar
Mine will do that too...
'97 F250 Ext Cab Long Bed 4x4
Stock Engine, For Now...
3 in Downpipe
4 in exhaust to 5 inch stack
97f2507 is offline
post #5 of 12 (permalink) Old 09-07-2011, 03:40 AM
im experiencing a very similiar issue. usually after engine is warmed up and been cruising down the interstate, and then get off and come to stop sign. the truck runs rough. (this has been going on for awhile now) today after work. about 70 degrees out; and got about 3-5 miles down the road; and it felt like the truck had a slight miss.
96 f250.
mrbp turbo back exhaust and beans diesel fuel system. 60 psi of fuel psi at idle. e4od trans. all pretty much stock.
any thoughts?
IDM?
HPOP?
IPR?
injectors?
thanks.
dmoon is offline
post #6 of 12 (permalink) Old 09-07-2011, 06:03 PM
cadd's Avatar
Well... I guess you could say we are not alone :)
Travis T
1999.5 F350 CC 4x4
cadd is offline
post #7 of 12 (permalink) Old 09-08-2011, 03:21 PM
Travis, did you ever replace your injectors.?
dmoon is offline
post #8 of 12 (permalink) Old 09-08-2011, 03:58 PM
cadd's Avatar
No, haven’t had the time or money Maybe after x-mas...
I've also been saving for a new transmission which I'm betting will go out on me right when I really don't need it to... :)
1999.5 F350 CC 4x4
cadd is offline
post #9 of 12 (permalink) Old 09-09-2011, 05:28 AM
Rough idle can be a symptom of lots of stuff so will list some simple low cost solutions/suggestions.
Clean oil/air filter and fuel filter.
Clean return fuel regulator screen found in the stock fuel filter housing driver's side 1/3 way down. Use diesel soaked Q-tips and flashlite and small mirror.
Install high pressure oil crossover line between heads.
Check for defective warn out stock dual mass flywheel.
Burnt Valve and Under valve electric harness at plugs to injectors.
Thats a start.....also check for codes.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4” exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #10 of 12 (permalink) Old 09-17-2011, 05:19 AM
cadd's Avatar
JCart,
Thanks for the info, I've rebuilt my fuel bowl not long ago so it's all clean.
I'm just betting tired injectors and injector orings are my issue.
Travis T
1999.5 F350 CC 4x4
cadd is offline
