??? about injector swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-29-2011, 01:32 AM Thread Starter
wrenchturner250's Avatar
My injectors are out right now getting redone by beans I was wondering if I should change oil on it while its down or would that be bad? Its due for the change and I'm switching to synthetic oil
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #2 of 5 (permalink) Old 03-29-2011, 01:34 AM
Busted Knuckles
PSDEng's Avatar
Re: ??? about injector swap
May as well. You won't be hurting anything.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #3 of 5 (permalink) Old 03-29-2011, 01:39 AM Thread Starter
I didn't think I would with all that cranking I'm gonna be doing figured id ask some other guys first
2007 f250 Sd fx4
post #4 of 5 (permalink) Old 03-29-2011, 02:03 AM
tonka350's Avatar
Nope you'll be perfectly fine bud, I did the same thing. I switched to synthetics and changed it all before I started it up.
Chad
00 F350, 08 clone, 3" cowl hood,billet grilles, 15" lift, 40" SS M16'S, 24X12 Rockstars, 2% tint, EBPV Delete, 4" duals w/7" tips, 6637 intake, WW, CCV Mod, PHP 80,120 race,140 Extreme, stage 1 single shots, 6.0 I/C
Chad
tonka350 is offline
post #5 of 5 (permalink) Old 03-29-2011, 02:30 AM Thread Starter
thanks sir glad to know im on the right track
2007 f250 Sd fx4
