Dana 60 passenger U-bolt plate - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 03-28-2011, 10:18 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Ok, so my D60 i got for my 97 is quite rusty. So rusty in fact that the passenger side U-bolt plate is rotten thru in a couple spots and paper thin in the rest. Does anyone know where to get another u-bolt plate? I would consider doing away w the u-bolt plate and just flipping the u-bolts but the trac bar mount is part of the u-bolt plate.
Bradbilt is offline
post #2 of 39 (permalink) Old 03-28-2011, 10:49 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Dana 60 passenger U-bolt plate
Can you say ROT
Bradbilt is offline
post #3 of 39 (permalink) Old 03-28-2011, 10:51 PM
WOW
02 f250
countryboyrob is offline
post #4 of 39 (permalink) Old 03-28-2011, 10:53 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
WOW
Welcome to the North east
Bradbilt is offline
post #5 of 39 (permalink) Old 03-28-2011, 11:31 PM
Im in michigan and deal with enough rust......Like the rear spring shackle mounts.
02 f250
post #6 of 39 (permalink) Old 03-28-2011, 11:46 PM
Krause's Avatar
Gonna be tough to find that piece Brad, seeing as though its welded to the axle tube and all. Its hard enough to find the driver's side ones kicking around; I have never seen that plate sold as a replacement anywhere to be honest, you may be s**t outa luck
96 XLT ECLB. 6.0 intercooler. 4" aero turbine, gearhead tunes. Coolant filter & CCV mod. SD Dana 60 3.73 3.5 RSK V-codes, 35 inch toyos, 18inch M/T classic locks. 260000Km
Krause is offline
post #7 of 39 (permalink) Old 03-29-2011, 12:41 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Well i took the grinder and hammer and got it off. I am going to hit 2 fab shops on the way home from work tomorrow and see if they would make one. If not I will but There is just so little time. just cant believe someone does not make something. I have seen the u-bolt reverser, making the u-bolt stradle the axle then come up thru a plate on top of the spring, but I would still need to make a trac bar mount
Bradbilt is offline
post #8 of 39 (permalink) Old 03-29-2011, 01:26 AM
Nose picker
Broncograveyard.com
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
post #9 of 39 (permalink) Old 03-29-2011, 02:04 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Originally Posted by Denver View Post
Broncograveyard.com
I am not seeing it. Do you have a link to the part?
Bradbilt is offline
post #10 of 39 (permalink) Old 03-29-2011, 02:12 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Broncograveyard.com
Is this the piece?
F350 Lower Front U-Bolt Bracket
It looks similar but no track bar mount. And I think that lays on top of the leaf springs
Bradbilt is offline
