Installed holley red fuel pump, still wont run. - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 36 (permalink) Old 03-28-2011, 05:41 AM Thread Starter
Re: Installed holley red fuel pump, still wont run.
Ok. If i replace the pump. I read there was something to worry about, falling into engine? Is the mechanical pump easy to replace or dangerous? And will the pump fail without weeping or leaking into oil?
Theworkunit is offline
post #12 of 36 (permalink) Old 03-28-2011, 05:43 AM Thread Starter
I have been scared to change pump because i dont want to ruin the engine if i drop something in it that shouldnt be.
post #13 of 36 (permalink) Old 03-28-2011, 05:43 AM
Marc's Avatar
Originally Posted by Theworkunit View Post
Haha. Yeah i'll have to remember that next time. Nastyf250 u own a 6.0 i feel ur pain. Any real suggestion on my fuel problem?
Im no moderator on this forum, nor do i carry any weight around here....But being an @%* to someone who seems to have the right idea on ways to help you is not the way to go........Especially when putting a fuel pump on a truck in a way that wont help it function was your answer. Just my two cents.......
And just for the record......Most 6.0 or 6.4 owners on these forums have owned or had pretty good experience with late model and OBS 7.3's......so just because he owns a 6.0 now, dont assume he doesnt know 7.3's as well.
I dont own a diesel at all.....So i guess by your statement above i dont know anything so you can disregard my post.
NHRDA Region 2 Race Director
Marc is offline
post #14 of 36 (permalink) Old 03-28-2011, 05:44 AM
crazed & deranged farmer
NutFarmer97's Avatar
Yes, there is a pushrod that rides on the cam. DO NOT DROP IT INTO THE MOTOR! the pump can be hard to pull out of the block if its been in for a long time. And yes a pump can fail and not seep or leak fuel to the outside of the engine or then oil system, but if you notice your oil level come up you have problems.
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #15 of 36 (permalink) Old 03-28-2011, 05:46 AM Thread Starter
Nastyf250 has been my good friend for over 10yrs. My post fell in behind yours but was not intended to u. He was just messing with me so i messed with him a lil too. Our other buddy drives a dodge. Just some inside joking. Sorry bout that.
post #16 of 36 (permalink) Old 03-28-2011, 05:49 AM Thread Starter
Nutfarmer. My oil pressure is running at normal when i have been able to get it running for a minute or two
post #17 of 36 (permalink) Old 03-28-2011, 05:50 AM
Marc's Avatar
LMAO..Well then i appologize for getting offended......Thats not what it looked like from my end.....It looked like someone offering advice and then getting the middle finger waved at them IMO even bad advice is worth considering if your to the point that your on a forum asking questions (beyond your knowledge/experience level in other words).
anyway....back to your regularly scheduled program them!!!
Marc is offline
post #18 of 36 (permalink) Old 03-28-2011, 05:50 AM
I didn't say oil pressure, I said level. As in checking the dipstick... if you engine "makes oil" then you have fuel leaking into the oil system.
post #19 of 36 (permalink) Old 03-28-2011, 05:51 AM
Marc's Avatar
have you actually tested the fuel pressure with everything hooked up in stock form??
Marc is offline
post #20 of 36 (permalink) Old 03-28-2011, 05:53 AM Thread Starter
Wen i remove the pump. How do i keep the push rod from falling in the motor? Magnet or something. Partially pull out pump then grab push rod with needle nose?
