4 door rear door gaskets? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-28-2011, 01:43 AM Thread Starter
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
Looking to get all new weather stripping is the front kit the same as the back kit 95 f350?
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
post #2 of 11 (permalink) Old 03-28-2011, 03:41 AM
biggreen96's Avatar
Re: 4 door rear door gaskets?
I believe the door gaskets are different. But I could be mistaken.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 11 (permalink) Old 03-29-2011, 05:13 AM
Demon Dually
speeddemon31176's Avatar
The gaskets are different but you could cut down a front door set to work on the back door with a little ingenuity.
speeddemon31176 is offline
post #4 of 11 (permalink) Old 04-01-2011, 01:41 AM Thread Starter
Brian
Who sells the gaskets for back doors?
post #5 of 11 (permalink) Old 04-03-2011, 03:10 AM
biggreen96's Avatar
Try jeffs bronco graveyard. I can't remember if they sell them or not
96 cclb f350.
idm mod,
afe stage 2 intake
srp1
intercooler
238/100
dp-tuner f6
T-4 mount and s470.
post #6 of 11 (permalink) Old 04-03-2011, 04:25 AM
Demon Dually
No one sells them. They are not available from any place including the dealer and online. I have searched high and low. If your gaskets aren't physically damaged then you can take them off and insert a piece of 3/8" surgical tubing through the loop portion of the gasket to restore the door sealing.
post #7 of 11 (permalink) Old 04-03-2011, 01:49 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Surgical tubing? Would aquarium tubing or washer/vacuum hose work?
Just curious about better sealing on my doors of a extended cab
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #8 of 11 (permalink) Old 04-04-2011, 12:17 AM
Demon Dually
Aquarium tubing would work if it is 3/8". The point of the size is to expand the original surface as much as possible for the best seal possible. I don't think you could ever get vacuum hose to slide down through the original seal, hence the point of the slick surface of the surgical tubing.
post #9 of 11 (permalink) Old 04-05-2011, 12:02 AM Thread Starter
Brian
damit. that blows
post #10 of 11 (permalink) Old 04-06-2011, 04:41 AM
I need rear door glass seals! I guess its called a window sweep on the bottom of the glass. Anyone seen these for sale?
97 F-350 PSD 5-Speed Manual 2-Wheel Drive Crew Cab DRW. 6637 Filter, MBRP 3" DP to 4" stainless, CCV Mod, TS Chip, 2012 crew cab Seats, Converted flywheel and clutch
Chewii is offline
