heavy exhaust out of upper radiator hose - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-27-2011, 03:49 PM Thread Starter
stoneykegonsa
I will start with the oil cooler first. What would be the next step? inj. cups I need to find out befor I pull motor.
stoneykegonsa is offline
post #2 of 15 (permalink) Old 03-27-2011, 03:54 PM
OEM Moderator
Tom S's Avatar
Re: heavy exhaust out of upper radiator hose
I do not see the oil cooler being your issue at all. Do all 8 cylinders have compression?
Tom S is offline
post #3 of 15 (permalink) Old 03-27-2011, 04:01 PM Thread Starter
stoneykegonsa
#2 is low/dead I would not think I could get thet much blow by with a bad inj. cup.
post #4 of 15 (permalink) Old 03-27-2011, 04:11 PM
OEM Moderator
Tom S's Avatar
I also would not think so. Time to dig in deep is my guess but you could pull that injector first if you wanted to be sure.
Tom S is offline
post #5 of 15 (permalink) Old 03-27-2011, 04:19 PM Thread Starter
stoneykegonsa
This was another obs I could not pass up all new stock inj. heavy rebuilt trany greese converision 4x4 ext. cab. Almost rust free col. truck. I know I will be pulling motor but would like to get it figured out first.
post #6 of 15 (permalink) Old 03-27-2011, 04:24 PM
Marc's Avatar
Let me get the story strait before i comment....
You have exhaust getting into the cooling system.....
And you have a dead #2 cylender???
NHRDA Region 2 Race Director
Marc is offline
post #7 of 15 (permalink) Old 03-27-2011, 04:32 PM Thread Starter
stoneykegonsa
Yes that is true.
post #8 of 15 (permalink) Old 03-27-2011, 04:39 PM
Marc's Avatar
Then more than likely you have either an issue with the headgasket or a cavitated cylinder wall from what i have seen. Your probably going to have to tear it down to find the problem. Sometimes cavitation is tough to find and you may have to have the head/block magnafluxed to find it depending on how big the opening is. Headgasket issues on the 7.3 are pretty rare but are very possible. Usually when they happend someone with a modified truck is running a tune with a lot of timing in it (usually a fuel economy tune) and they get on it hard and the timing builds too much cylender pressure for the stock headbolts.
In order for it to be an injector cup, you would have to have both a comnpletely burned up copper washer on the injector tip, and a cracked injector cup. Usually you would see a fuel in the coolant issue long before you would ever get exhaust into the cooling system....but i suppose it is possible.
Marc is offline
post #9 of 15 (permalink) Old 03-27-2011, 04:44 PM Thread Starter
stoneykegonsa
It is #4 thats dead not #2.
post #10 of 15 (permalink) Old 03-27-2011, 04:47 PM Thread Starter
stoneykegonsa
Yes the kid did have a TS can tuner on it.
