torque converter lockup interference questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-27-2011, 01:45 PM Thread Starter
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
so long story short if you read my other thread you would know that i put retrosoloutions led tail light bulbs in and they started a few issues, one that conserned me was that when you put the marker lights on the torque converter would unlock. we put resistors in the lights. problem solved. now if the marker lights are on and i put the right turn signal on it unlocks, but not the left. but my question is could there be an issue with the wiring on my truck? how is the lockup controlled? also am i hurting anything with it unlocking at highway speeds momentarly?
also im not complaining about retro's product they are top notch im just trying to narrow down my problem and get it solved
heres a link to the other thread
https://powerstrokenation.com/forums/...ad.php?t=95430
thanks guys
Refugee
pstroke96 is offline
post #2 of 4 (permalink) Old 03-29-2011, 05:15 AM
Demon Dually
speeddemon31176's Avatar
Re: torque converter lockup interference questions
More resistors are in order for the brake/turn signal wires as well.
speeddemon31176 is offline
post #3 of 4 (permalink) Old 03-30-2011, 02:43 AM Thread Starter
pstroke96's Avatar
thats what im leaning twards, im trying to work it out with todd at retro, i just wanted to ask up here to see if possibly there is an issue with the wiring in the truck not just the lights
Refugee
post #4 of 4 (permalink) Old 03-30-2011, 06:02 AM
Demon Dually
It is not the wiring in the truck, it is a lack of proper load when illuminating the bulb that is causing the issue.
