Code questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-27-2011, 01:54 AM Thread Starter
< Can I drive?!
wint's Avatar
Code questions
Hooked up a friends scan guage tonight and threw these codes. If some one could tell me what they are or show me where to go that would be awesome. Thanks!
P0238
P0500
P0344
P1111
P0478
P1211
The Army wants you!
wint is offline
post #2 of 11 (permalink) Old 03-27-2011, 01:55 AM
Busted Knuckles
PSDEng's Avatar
Re: Code questions
Check out the library.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #3 of 11 (permalink) Old 03-27-2011, 01:55 AM
Re: Code questions
I know p1111 is everything is checks out ok.
02 f250
countryboyrob is offline
post #4 of 11 (permalink) Old 03-27-2011, 02:41 AM
Re: Code questions
Thats right after I deleted the codes.
Ill look them up for you man.
late 99 black CCSB
OUTLAW101 is offline
post #5 of 11 (permalink) Old 03-27-2011, 02:44 AM
Re: Code questions
OBS PCM Codes - PowerStrokeNation
late 99 black CCSB
post #6 of 11 (permalink) Old 03-27-2011, 02:50 AM
Re: Code questions
P0238 Turbo Boost Sensor A Circuit High Input
P0500 Vehicle Speed Sensor (VSS) Malfunction
P0344 CMP Sensor Circuit Intermittent
P1111 System Pass (No DTCs Available)
P0478 Exhaust Pressure Control Valve High Input
late 99 black CCSB
post #7 of 11 (permalink) Old 03-27-2011, 04:55 AM Thread Starter
< Can I drive?!
wint's Avatar
Re: Code questions
What would be the VSS sensor code? And what the heck is a CMP?
The Army wants you!
wint is offline
post #8 of 11 (permalink) Old 03-27-2011, 03:19 PM
Re: Code questions
The VSS is that sensor in the top of the rear axle. I would pull it check and see how much crud is on it, check the wires for any breaks and go from there.
02 f250
post #9 of 11 (permalink) Old 03-27-2011, 04:20 PM Thread Starter
< Can I drive?!
wint's Avatar
Re: Code questions
Alright ill look. Would it have anything to do with the transmission?
The Army wants you!
wint is offline
post #10 of 11 (permalink) Old 03-28-2011, 03:22 AM
JFURNER77
JFURNER77's Avatar
Re: Code questions
CMP is how Ford catalogs what we call the CPS.
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
