??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-26-2011, 05:41 AM Thread Starter
OBSdan's Avatar
Was driving at night and both head lights shut off and the highbeam light came on. Anyone know wat may have happen. I'm not the greatest at trouble shooting
OBSdan is offline
post #2 of 2 (permalink) Old 03-26-2011, 08:39 AM
Demon Dually
speeddemon31176's Avatar
Re: ???
Check the plug behind the drivers side turn signal. There is a small harness that plugs into a dummy plug that bypasses where the DRL module would be. If that came unplugged that would cause the problem you are having. If that is not the issue then I would look at the multi function switch for the headlights, turn signals, wipers.
speeddemon31176 is offline
