over drive light flashing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-26-2011, 05:33 AM Thread Starter
i was driving down the road and noticed my overdrive light was flashing. the tranny still shifts fine can anyone tell me why its doing this???
96 F-250 ext cab. straight axled 6" lift. intake, exhaust, ts with wide open performance tunes. torque converter, shift kit
cherrytr is offline
post #2 of 15 (permalink) Old 03-26-2011, 08:40 AM
Demon Dually
speeddemon31176's Avatar
Re: over drive light flashing
Without knowing what the code is we would only be making expensive guesses. Get it on a high end scanner and let us know what the code(s) are. Parts store scanners can't read the codes on these trucks.
speeddemon31176 is offline
post #3 of 15 (permalink) Old 03-26-2011, 09:10 AM
policefordtuff's Avatar
Mine did that and its in the shop now getting a tranny rebuild. But mine wouldnt take off in first gear....it started in 2nd. But it did shift fine through everything else. Just no first gear! Hope you have better luck than me! Keep us posted!
policefordtuff is offline
post #4 of 15 (permalink) Old 03-26-2011, 04:43 PM Thread Starter
i let it sit over night. drove it is has first and shifts through all gears and now the light is off. i scanned it didnt have any codes but was a quart and a half low on fluid so i filled it up and the light hasnt cam back on.
cherrytr is offline
post #5 of 15 (permalink) Old 03-26-2011, 04:45 PM
What did you use to pull codes?
02 f250
countryboyrob is offline
post #6 of 15 (permalink) Old 04-04-2011, 04:56 PM Thread Starter
i am using a snap on scan tool and the code it keeps pullin is a p1728 code
cherrytr is offline
post #7 of 15 (permalink) Old 04-04-2011, 07:17 PM
crazed & deranged farmer
NutFarmer97's Avatar
I believe that is a trans slip code. My truck did the same and I ended up having to rebuild my trans because the lock-up in the TC burned out. It will shift through all the geard but the TC may not be locking up like it should.
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #8 of 15 (permalink) Old 04-06-2011, 01:31 AM
444CuiOBS's Avatar
Hey nutfarmer, what did your trans rebuild run you? I believe my trans is stock and I plan on setting some cash aside every month for a future rebuild.
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #9 of 15 (permalink) Old 04-06-2011, 02:11 AM
Mine was about $3,700. triple disk billet converter, steel planetary's, trans go tugger, extra clutches in 3rd gear, I think there was a billet input shaft and a few other goodies. I had it done at a local trans shop.
post #10 of 15 (permalink) Old 04-06-2011, 12:04 PM
Demon Dually
That is a torque converter slip code. Your converter is crapping out and by now has sent all kinds of garbage through the trans. A complete rebuild is in your near future.
