range sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-25-2011, 09:48 PM Thread Starter
Shaun Lindmark's Avatar
range sensor
Hey guys I have a random question. Can a range sensor on the transmission cause the engine to have low power. Reason I am asking is because when in stock with out a chip it has no power and doesn't shift very good ?
Oxford White 2011 f-250 Lariat ccsb 6.7 Stock for now
1995 F-250 ext. Cab 7.3, New paint, Rosewood Stage 2 160/80%,TS 6 Pos Chip with PHP tunes, D60 conversion, 6637 filter, ccv, 3" dp 4" straight piped no cat or muffler, 7.3 intercooler with banks piping kit, and air ride 5000 rear air bags. SOLD
Shaun Lindmark is offline
post #2 of 11 (permalink) Old 03-25-2011, 09:53 PM
Re: range sensor
Your comparing apples to oranges guy. A stock obs is about as gutless as can be.
02 f250
countryboyrob is offline
post #3 of 11 (permalink) Old 03-25-2011, 09:58 PM Thread Starter
Re: range sensor
I know what your saying man I hope your right but I have a couple people telling me there is def something up psd owners that are on this forum. Also why does that chip I bought not work in my truck but does in others that have the same exact truck lol.
post #4 of 11 (permalink) Old 03-25-2011, 10:01 PM
Re: range sensor
Are those trucks already tuned? Did you clean off the tab for the pcm?
Besides you assuming that your truck is lacking power what else is wrong?
02 f250
post #5 of 11 (permalink) Old 03-25-2011, 10:11 PM Thread Starter
Re: range sensor
They are now but they weren't before. yes the tabs are cleaned because when I bought the truck it had a single position diablo sport chip in it and runs perfect with that in it. shifts good plenty of boost etc. I bought a ts chip from my buddy who has the same exact truck and it does all kinds of weird stuff. now with no chip/tune on it it has no power and shifts weird/ hard especially at wot. now other than that the engine runs smooth always starts idles great and everything. I feel like I have go through every inch of this thing and can't find anything wrong or bad. I know these things are gutless pigs but I dnt think this bad I mean if I put my boat on the back I feel like it wouldn't pull it. maybe your right its just that bad in stock form and shift that crapy and I am use to a chipped truck but damm. also why wouldn't the ts work when it works in 4 other obs psd I have tried
post #6 of 11 (permalink) Old 03-25-2011, 10:20 PM
Re: range sensor
Is the chip burned for the right pcm code?
02 f250
post #7 of 11 (permalink) Old 03-25-2011, 10:24 PM Thread Starter
Re: range sensor
I would assume yes because both rucks were 1995 not 100% though
post #8 of 11 (permalink) Old 03-26-2011, 12:47 AM Thread Starter
Re: range sensor
Bump anybody else have any input
post #9 of 11 (permalink) Old 03-26-2011, 01:09 AM
crazed & deranged farmer
NutFarmer97's Avatar
Re: range sensor
Just because they were the same year dosen't mean they have the same pcm code, one could be a CALI truck also auto vs. manual will have different codes.
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #10 of 11 (permalink) Old 03-26-2011, 02:40 AM Thread Starter
Re: range sensor
It was a buddies truck and it was an auto like mine and def was not a cali truck.
