Batteries Draining overnight?!?!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-25-2011, 09:21 PM Thread Starter
powerstroke095's Avatar
Ive been having this problem lately where my batteries will drain overnight and the truck wont start in the morning. I went and had the batteries checked and they tested good, we tested the alternator and it was toast so i replaced that and still acts the same.
What could be causing the batteries to drain like this? the battery gauge on the dash reads good the headlights don't really dim at all either, if i hook the jumper cables to it, it fires right up
Maybe a bad connection or short somewhere between the battery and alternator?? or battery and starter???
Thanks
Josh
Josh
95 F-250 ext cab lwb 4x4
custom tuned TW chip
modified H2E
DIY electric fuel
Valair ceramic clutch
Intercooled
4'' straight pipe
Dana 60 conversion in progress
powerstroke095 is offline
post #2 of 8 (permalink) Old 03-26-2011, 12:25 AM
excavator's Avatar
Re: Batteries Draining overnight?!?!?
You may have a short or a parasitic draw and you can check which circuit by using a 10 dc ammeter. You disconnect the negative battery cables and then hook the test leads between the negative cable and the negative battery post and read the draw. If there is a draw of 35 milliamps, or .035 amps or higher then you have a problem. First thing is to remove the alternator heavy cable to eliminate the alternator. If still a draw then remove each fuse one at a time until the draw is gone and then you found what is draining the batts.
Here is good article on this test. http://flashoffroad.com/electrical/B...teryDrain.html
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #3 of 8 (permalink) Old 03-26-2011, 01:13 AM
Built not Bought
1990 Scorpion's Avatar
I have the exact same problem my batteries drain down overnight but still have enough to barley crank the truck, so I'm all ears on this one.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #4 of 8 (permalink) Old 03-26-2011, 01:24 AM
excavator's Avatar
Follow my recommendation
post #5 of 8 (permalink) Old 03-26-2011, 08:50 AM
Demon Dually
speeddemon31176's Avatar
What excavator said is exactly how to find your draw on the batteries.
speeddemon31176 is offline
post #6 of 8 (permalink) Old 03-29-2011, 05:15 PM
96P_Stroke4x4's Avatar
once i had that problem too and the glow plug relay it ended up being stuck. new GPR and all was well. just another thing to check out.
'96 F-250 XLT,x-cab,4x4,BTS,363k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust,twin 6" stacks,Tymar, Boost Pyro Tranny and white-faced gauges,I/C,onboard air,HX mod,TW 6-position chip
96P_Stroke4x4 is offline
post #7 of 8 (permalink) Old 11-08-2014, 09:16 PM
Smile Re: Batteries Draining overnight?!?!?
Okay, this is my first post and I don't have much time right now but....
I had this battery drain problem recently and found that the glow prug relay was continuing to power the plugs. I replaced relay with the White-Rodgers? part that was recommended here, I think. No fix. Then, I saw that the PCM is supposed to drop a ground after some calculated time to turn off the relay so, I removed the PCM thinking it might be the problem. I found that the cable connection to the PCM had some corrosion/oxidaton on some of the male pins and some female holes so, I cleaned them up...small wire brush on pins and a push pin in the holes. Reassembled and...problem fixed! I am a happy camper.
I hope this helps someone as I appreciate the help that I have gotten here. You guys put me on the right track. I will check back later to see if you have any questions.
Cheers,
LndCrsr is offline
post #8 of 8 (permalink) Old 11-09-2014, 01:46 AM
csp
I would hope that after 3+ years they have figured out the battery problems.
Look at the dates on this thread....
csp is offline
