IDM Failure related to Alternator Failure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-25-2011, 05:22 AM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Recently found out my IDM was shot, the alternator was found out to be dead too... Could these be related?
Good place to find a IDM??
How do IDM's go bad?
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 7 (permalink) Old 03-25-2011, 02:41 PM
zilla68's Avatar
Re: IDM Failure related to Alternator Failure
I think the common failure for them is water intrusion, but as with any thing electrical, it only takes a quick short, spike etc, to blow something out.
have you opened it up to look inside?
idm's for sale in the classifieds below quite often.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #3 of 7 (permalink) Old 03-28-2011, 04:45 AM
Fixing Broken Stuff
toolmangary's Avatar
What makes you think your IDM is shot? I don't see how the two are connected, but who knows????
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 7 (permalink) Old 03-29-2011, 05:26 AM
Demon Dually
speeddemon31176's Avatar
The only way they could be connected is if the alternator had a massive high voltage spike and burnt out the IDM, however if that were the case anything else that is electrical in your truck would have suffered damage as well. On the flip side though is that if your alternator wasn't putting out enough amps to keep the batteries charged and the voltage got too low then the IDM, PCM, etc would not be able to function and therefore the truck wouldn't run that way either.
speeddemon31176 is offline
post #5 of 7 (permalink) Old 03-30-2011, 11:37 PM Thread Starter
Underfunded
moonshiner's Avatar
IDM was shot, replaced it with a GB remanufactured model. and the alternator was shot as well.
Not sure if they were connected, but truck starts now and runs better.
2010 VW Jetta 2.5
post #6 of 7 (permalink) Old 04-01-2011, 06:08 AM
Demon Dually
I would say that it was purely coincidental.
post #7 of 7 (permalink) Old 05-09-2013, 10:31 PM
I think this may not be coincidence. I have replaced my IDM twice now within about 50,000km. The second time, the alternator was kaput at exactly the same time...
Expensive!
g-haad is offline
