synthetic oil questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 03-24-2011, 04:41 PM Thread Starter
wrenchturner250's Avatar
I here a lot of you guys are running synthetic oil, what I wanna know is does it run better, what brands are good and would it be safe to switch at 213k?
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #2 of 20 (permalink) Old 03-24-2011, 04:55 PM
Re: synthetic oil questions
I changed mine over to mobil 1 5w-40 for the winter. i keep mine in a heated garage and it seems to start a lil easier, injectors are a tad quieter. no performance gains are noticed, throttle response the same. When it sat outside in the cold that 5 weight makes it alot happier when starting. hope this helps.
95 F-250 plow/work truck, Meyer 7.5 ft plow, lift gate, cat delete, straight pipe, fact. no A/C, CCV Mod, Tymar intake, Diesel Site trans filter, SD tensioner
bigblock_ford1969 is offline
post #3 of 20 (permalink) Old 03-24-2011, 05:25 PM Thread Starter
I live in oregon I see cold weather but not offten, just trying to decide if its worth the extra money
2007 f250 Sd fx4
post #4 of 20 (permalink) Old 03-24-2011, 05:36 PM
GoNavy!
DcMoore999's Avatar
It is worth the money.. My trucks love it! And you'll be alright switching over at that mileage.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #5 of 20 (permalink) Old 03-24-2011, 07:28 PM Thread Starter
Okay think I'm gonna give it a shot
2007 f250 Sd fx4
post #6 of 20 (permalink) Old 03-24-2011, 07:58 PM
Exploding the magma
rufushusky's Avatar
Yeah you can switch back and forth at will. HEUI injectors like synthetic oil!
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler, Zone offroad leveling kit, Western UM 8'6" plow
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
rufushusky is offline
post #7 of 20 (permalink) Old 03-24-2011, 08:35 PM
morefuel's Avatar
I've been thinkin about doing the same. Does a person need to run a semisynthetic between changes? I have heard that synthetic oil and mineral oil don't like to mix.
97 f250, ZF-5 tranny, 6637, 3" round downpipe 5" exhaust, PHP six position, 6.0 liter I/C, DIY exhaust brake, 05 axle swap, 280HP 551 ft. lbs.
morefuel is offline
post #8 of 20 (permalink) Old 03-24-2011, 08:37 PM
Exploding the magma
rufushusky's Avatar
No they play just fine together.
post #9 of 20 (permalink) Old 03-24-2011, 09:27 PM
LiftedSuzuki's Avatar
Valvoline says you can run half conventional and half synthetic if you want, no problems what-so-ever.
1995 F-250 7.3L 5 Speed, 4" Lift, 35" Toyos, Straight Pipe, DIY 6637 Intake, TS Chip with PHP Tunes, Glowshift Gauges
LiftedSuzuki is offline
post #10 of 20 (permalink) Old 03-24-2011, 09:56 PM
GoNavy!
DcMoore999's Avatar
And if your feeling bored suck out the oil in your hpop resivoir and refill it with the good stuff
