'97 7.3 won't start unless... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-23-2011, 05:27 PM Thread Starter
CowboyLogic's Avatar
the block heater is plugged in for a couple of hours.
I live in Alberta, so it does get cool here. Normally this truck will start easily in 23 degree weather without being plugged in. Now it won't start if left overnight without the block heater plugged in. It will just turn over and over. If I plug it in for a couple of hours it fires right up. Here's what I know...
  • Batteries show full charge in the morning on my DVM.
    I see my Tach move when cranking and to my ear its cranks at the usual speed.
    Oil level is good.
    Oil changes and filters done regularily.
    Fuel in the tanks
    The "wait to start light" comes on and off like it usually does.
Should I concentrate on proving the issue to be Glow Plugs? I have checked the library here and found info on how to check the Glow Plug relay as well as how to R&R the Glow Plugs. Am I heading up the right path? Thanks guys. This is a fantastic site. - Darrell
CowboyLogic is offline
post #2 of 19 (permalink) Old 03-23-2011, 05:35 PM
psdguy97
psdguy08's Avatar
Re: '97 7.3 won't start unless...
Have your gp's been replaced?
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
post #3 of 19 (permalink) Old 03-23-2011, 05:38 PM Thread Starter
Not since I have owned truck, which is 3 years.
post #4 of 19 (permalink) Old 03-23-2011, 05:40 PM
psdguy97
psdguy08's Avatar
I would say it's time for new gp's man. While your in there I would change your uvch and gasket. As well as a new gp relay. That way your set for a long time.
95 F-250 ECLB
psdguy08 is offline
post #5 of 19 (permalink) Old 03-23-2011, 05:42 PM
Harl
Harl's Avatar
Send a message via AIM to Harl
Check the glow plug relay.. Sometimes they will burn up. Sometimes cycleing the key a few times will help to if the relay isnt bad.
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #6 of 19 (permalink) Old 03-23-2011, 05:50 PM Thread Starter
Thanks for the quick answer psdguy. I'm no diesel mechanic but with sites like this that tap into helpful peeps like you, cheep guys like me get "er" done. Thanks for the help. BTW, would you be comfortable buying these parts at an auto parts store? -Darrell
post #7 of 19 (permalink) Old 03-23-2011, 06:52 PM
zilla68's Avatar
no, order the zx-11 motorcraft glow plugs, the others can swell in the head and cause you great deals of pain!! also do the glow plug relay from stancor.
i think someone on here offers the entire kit with all the right stuff for your convienence!
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #8 of 19 (permalink) Old 03-23-2011, 07:11 PM Thread Starter
Thanks for the tip zilla, I will see if I can find who you are talking about there.
post #9 of 19 (permalink) Old 03-23-2011, 07:59 PM
psdguy97
psdguy08's Avatar
No problem dude. I'm no diesel mechanic either but this site has taught me a lot. I just did gps for the first time the other day an it's not hard. Just take your time. And no I wouldn't buy this kind of stuff from a local part store. Always motor craft stuff when it comes to motor parts. And I would go with a stancor relay as satiated above.
95 F-250 ECLB
psdguy08 is offline
post #10 of 19 (permalink) Old 03-23-2011, 08:01 PM
psdguy97
psdguy08's Avatar
I believe some of the sponsors on here sell gps. They might be cheaper than going to ford.
95 F-250 ECLB
psdguy08 is offline
