Fuel Gauge Issue/Maybe bad Pick Up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-23-2011, 03:25 PM Thread Starter
96Powerstrokin's Avatar
I replaced the injector o-rings on my truck and everything ran good for a few tanks. But lately my gas gauge moves all around when driving like the tank is sloshing and if I put 5 gallons in the rear tank. It will move to a quarter and then as soon as I leave go to e and at 55 miles later the truck will run dry. I used to be able to go 85-95 miles on 5 gallons? Is it possible the pick up is broke off and the truck is actually not running dry?
2008 F250 CCSB 4x4, 101K Stock
2004 F350 CCLB FX4, 6.0, 4x4, 2.5 Leveling Kit, 305s, SCT Tuner, 260k, Built Trans with Triple Disc Billet Converter. - SOLD
1996 F250 SCLB 4x4, E40D, Powerstroke, DIY Intake, EBPV Delete, DP Tuner, 4 In Lift, 342k - SOLD
96Powerstrokin is offline
post #2 of 5 (permalink) Old 03-23-2011, 04:23 PM
washingtoncoastie's Avatar
Re: Fuel Gauge Issue/Maybe bad Pick Up
Depending on your location, you may be just running winter blend fuel which will drop you mpg's a few. The fuel gauges on these trucks bounce a lot.
washingtoncoastie is offline
post #3 of 5 (permalink) Old 03-23-2011, 08:01 PM Thread Starter
I am in North Carolina and I wasnt having this problem at the beginning of the month
post #4 of 5 (permalink) Old 03-24-2011, 04:34 PM
Cratos's Avatar
the pickup umbrellas rot and fall off. so at 1/4 tank you run out the broken pieces could be banging the level rod causint the bouncing around.is it doing it on both tanks or just one? when mine went I had pulled both tanks the other one was about to go too.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #5 of 5 (permalink) Old 03-25-2011, 03:32 PM Thread Starter
Mine is doing it on the front tank more but the back tank is doing it too just not as bad. If that makes sense is there a link to a thread on here to fix it?
